Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 151
Thread: r154 shifting experiences
  1. #61
    Default Re: r154 shifting experiences
    negative...didnt do it on mine...totally forgot
    I think dong had it done as well...maybe ask him?
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
  2. #62
    get a new one from toyota
    have an oil gallery cut into the side that doesnt have one
    old mate did it and put his through many 6K rpm launches with slicks and a solid centre twinplate to run 10.1 passes with a 450rwkw 2JZ
    Wouldnt the new one from Toyota be the same as the original weak item?
    Wouldnt cutting an extra slot in it weaken it further?
    I thought it was shifting hard between gears that smashes it, not power.
    See: http://store.driftmotion.com/static/...rustwasher.php
  3. #63
    I was always under the impression it became weak because oil didnt get down both sides
    that one on the driftmotion site seems quite nice though...hmmm
  4. #64
    BHGBTDT Domestic Engineer kemicalx's Avatar
    damn i would have loved to have seen that site before i rebuilt mine...
  5. #65
    Yeah, they have some nice bits on there for decent prices.
    Glad i came across it sooner rather than later.
  6. #66
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Chris (Disturbed) has smashed a few, he would be one to ask.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
  7. #67
    Yep. Just a new factory Toyota one with additional oil gallery.
    Sorry no pics.
  8. #68
    Quote Originally Posted by Pimpin_1JZ
    correct
    if u ask me - they fail because the harden surface weaks out and the weakest part is the notched key way - which if i were to redesign one - would be replaces with a ball bearing drive.
    dont have to deal with this issue no more but
    BTW im pretty sure a landcruise thrust washer and a supra r154 thrust washer share the same part number anyway
    Signiture edited..... Read the Rules
  9. #69
    4 out of 5 breaks are completely symmetrical, the only one that isnt is in the keyway which makes me think the opposite...
    JZA70|R / 12.45 @ 111 mph.
  10. #70
    Is awesome Backyard Mechanic
    Jan 2008
    Off Topic;
    What is the best wat to change/get rid of that yellowish RL LW SP out of the box? completely?
  11. #71
    unless you pull the box down or flush it with something else nothing.
    if you drive the car for a bit before you drop the oil it will be hot and thinner visc and in theory should drain quicker and easier.
    I doubt <~5% contamination will do any harm...
  12. #72
    Bunbury W.A.
    Use auto trans fluid like dexron 3. It is thinner and will flush it nicer. Only use for it for like one drive then dump it.
  13. #73
    Mar 2008
    Just posting back for future players - I put RLSP in my r154 some months ago now after reading the info in this thread, so far so good. It improved the shifter feel between gears and has held up to some heavy launches at the strip which were enough to weld my button clutch to the flywheel on one occasion.
    If your thinking about using it... it's atleast worth a try, working well for me!
    OT: I've been waiting for the thrust washer to go - was going to make one, seems simple enough?
  14. #74
    How hard is it to replace one of thse washers? And what happens when one lets go??? Things stop working?
    I didnt use the shockproof, but i used the other Redline oil, MTL i think it was, and my gearbox shifts i think about the same... Havent noticed any gains, but i been using it for a while so i cant remember...
    Infact i mighta already posted my opinions in here
    Jase
    JZA023
  15. #75
    easy to replace if u mehanically minded.......
    when mine let go - it wouldnt let me pull away in 1st gear....
    when i put it first it didnt feel right, then when i tried slipping the clutch ot get away it popped out with a nasty crunching sound...
    besides that drove fine in any other gear - got me home 30 ks
  1. 1JZ R154 Spigot bearing
    By rogue-vl in forum Tech and Conversions
    Last Post: 08-03-2011, 01:31 PM
  2. R154 gearbox rebuild gone wrong
    By Esselte in forum Tech and Conversions
    Last Post: 18-04-2006, 12:24 AM
  3. rebuild or new r154?
    By Xistant in forum Tech and Conversions
    Last Post: 29-12-2005, 07:11 PM
