Results 16 to 28 of 28
Thread: engine run in/first start.. Now with smoke
    Default Re: engine run in/first start
    bit of a thread bump. I driven around a couple of times round the block up some hills etc prob not even 10k's but i'm getting some large clouds of blue smoke on start up
    So its obviously burning some oil on start up havent checked the dip stick yet though. But is this something that should stop once the rings wear in a bit more??
    Aug 2010
    Default Re: engine run in/first start.. Now with smoke
    From what I understand a bit of burning oil is perfectly normal on a brand new engine. If its still blowing smoke after 100ks it might be a problem, but after 10ks I wouldn't stress. If anything its an excuse to go out and thrash it hard.
    Aug 2009
    Did you replace everything.. Etc stem seals etc? Or jus refresh the bottom end?
    valves where re seated and i'm fairly certain stem seals where done. i'll keep driving it for a while and see if the problems go.
    can any of those "stop smoke" oil additives help if the problem doesn't go away?
    Nah, the stop smoke additives are for old worn engines where rings/seals are farked from age, and just thicken up the oil.
    See how she goes with a few more kms under the belt. Give her some good berries through the mid range though.
    Chiba
    10kms isn't nearly enough time for the engine to bed in. Give it a bit of stick (load up the engine) for a few hundred kms and you should be fine.
    yeah every time i've driven round the block etc i've given it a fair bit... well as much as 33kw of power will get me.
    Tallahassee, FL USofA
    Quote Originally Posted by HAVABEER View Post
    ...is this something that should stop once the rings wear in a bit more??
    No, most of the ring bedding was done in the first 5 minutes, 95% IMO, and every thing else is just fine tuning with relatively little affect.
    Good luck.
    Quote Originally Posted by banana_socks View Post
    2nd'd'd
    give it heaps and see how it is after 150km.
    Never late in an x8
    Thread Hijack:
    Should I run in my new gze with or without the SC14 switched on? ie boost or no boost?
    With boost, just limit your right foot activity to ensure you don't red line it or drop skiddz. The extra pressure of the boost on the rings will help them to bed better.
    Apr 2008
    Quote Originally Posted by old_mr2 View Post
    Thread Hijack:
    Run in mine with the SC14 on and my engine builder recommended the same. Don't see any reason to have it off....
    Cool, thanks for the info.
  1. 4agze ae92 AFM - Complete guide - doin it the hard way
    By ONETEN in forum Engine & Driveline Conversions
    Last Post: 19-03-2012, 04:30 PM
  2. 5M E to 5M GE/6M GE Conversion Guide
    By spiller in forum Engine & Driveline Conversions
    Last Post: 29-11-2011, 12:03 PM
  3. MA70 --> JZA70 Conversion
  4. my masochist engine swap... 3S to RWD
    By Roman in forum Engine & Driveline Conversions
    Last Post: 10-04-2007, 10:22 PM
