Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: the ducks nuts in responsive turbos?
    Default the ducks nuts in responsive turbos?
    So toying with the idea of a new pair of turbos. They need to flow a max of 400hp each and have very good boost response on a high comp, hi flowing 2 litre (x2 for 4 litres).
    the garret 2871R seem to deliver the goods and gets good things said about it? I want to use the Tial V-band style turbine housings too as they are nice and light and punch above their weight in flow capacity...i'm thinking i'll stay tight with a 0.63 a/r
    Basically aiming for 350rwkw at 10psi (which my current KKKs will do) but with improved response if i can get it (not that the KKKs are poor).
    thoughts? better options?
    Default Re: the ducks nuts in responsive turbos?
    Which kkrs are you using?
    KKK not KKR.
    If in doubt power out
    Quote Originally Posted by mullett View Post
    These ones
    They are heaps responsive with the darker kind are around.
    RAAFENG Domestic Engineer punkture's Avatar
    Apr 2008
    i wonder if there hat is multi purpose, after they give their hats to their wives (obviously in the kitchen) and she uses them as a cream/cake decorater?
    Current: 1990 ST185R Celica:
    http://www.toymods.org.au/forums/showthread.php?t=62315, DAEWOOOOO ESPERO
    Previous: Ta22 4aGZE; Older: 99' WRX Impreza 192kw
    err thanks guys...
    wa
    short of goin to billet turbo's with those fancy bearings?
    i've heard borg-warner with extended tip are good?
    http://www.turbodriven.com/en/perfor...owerRange.aspx
    Aug 2009
    D.Svetice 107, Croatia
    Justen
    new BW with ceramic ball bearings and extremely light exhaust wheel are super suited for your application.
    check them here:
    http://www.full-race.com/store/turbos/borgwarner-efr/
    Junior Member Backyard Mechanic HIZOKU's Avatar
    May 2006
    TR30 garret
    if you can find one this is what most race car teams use
    [Gentlemen's Club]
    Quote Originally Posted by TH Performance View Post
    Justen
    check them here:
    Ta mate, those EFR model looks like excellent bits of gear. I currently run x2 K26 turbine with a K27 compressor and front cover...external gates.
    The 6758 looks to be a good match for approx 300hp at around a 1.8-2 pressure ratio. The smaller model would be perfect for a genuine race engine running more boost but i'm trying to keep my setup fairly lazy as i'll need to get a good few years out of it
    Price has killed the whole exercise dead in the water though It would the best part of $4000 once they were landed which i can't justify given my current setup seems to work pretty well.
    I could get garretts on there with the Tial turbine for close to $2K, which is very tempting...but jeez, i'd hate to put new turbos on there and go backwards?
    Jul 2009
    map wise i think the 2860R from garrett will be better suited to you? 2871 is a high boosting turbo, never sees its happiest place at 10psi.
    Dare I say the 2560 might just scrape in your horse power figure? Should respond like crazy on your built motor.
    Quote Originally Posted by Supra967 View Post
    That's the issue with all the Garretts it seems? They have quite steep maps and like a high PR for efficient flow.
    The 2560 won't make 30lbs/min until big boost either unfortunately. The KKKs and BW on the other hand seem to have a very wide efficiency range in comparison.
    I replaced the KKK on my old GTFour with a GT2540 and went backwards everywhere except peak hp, where it delivered a minor gain. Car was way slower overall though On paper it should have been light years ahead? I don't want another experirnce like that !!
    Aug 2009
    in my opinion there is no point spending money to replace them unless you go the best and spend the 4k otherwise just stick with what you have and save, as replacing with something cheap isnt goin to be worth the effort
  1. Aluminium Wheel Nuts - Use Care - Lost a wheel at 60km/hr today - stripped bolts PICS
    Last Post: 28-02-2007, 02:46 PM
  2. Turbos 101
