Results 1 to 9 of 9
Thread: Caldina ecu help
    Jul 2009
    Exclamation Caldina ecu help
    Hi guys,
    Just wondering if anyone knows of a plug and play ems for the st215 or if the st205 uses the same plug arrangement?
    All help greatly appreciated :-)
    Previous ride ST215 Caldina GT-T
    Screamer pipes, quiet when you want them to be and loud when you wanna gate old ladies at the bus stop...
    Default Re: Caldina ecu help
    I have searched long and hard and haven't found a PNP unit for the Caldina. My understanding is the ecus are quite different to the Gen 3 but have no idea on pinout/plug arrangement etc ie Gen 4 runs Coilpack vs Dizzy so has different cams, high impedence vs low impedance injectors, higher compression etc.
    Whatever happens the base map for the Gen3 PNP ecu is not even going to come close to running the car.
    If in doubt power out
    Jul 2009
    Thanks Rona can always count on you
    Ps turbo arrived will post pics in my thread soon
    Oct 2010
    New Zealand
    I'm not sure if this is relevant to the topic, but my brother installed a Mine's ECU into his ST215 Caldina about 6-months ago and it made a hell of a difference. It was completely plug-and-play and it only took a couple of days for the ECU to really settle itself in. Unfortunately they're as rare as hen's teeth these days, but if you can find one then it's a quick and easy mod that's sure to put a smile on your face.
    The issue with the Mine's ecu is they aren't tuneable so are completely useless to anyone modding to the extent of Haynesie and my eventual plans.
    Jul 2009
    Ohwell splice and dice lol!
    http://www.toymods.org.au/forums/sho...postcount=1762
    Check that post out and maybe ask for more info.
    JP made a plug and play loom for a Vipec ECU to suit a Caldina.
    I'm pretty sure he used 1zz-fe connectors etc, but I'm also sure that no other ecu loom will work. And Also you will need different Auto to Manual ones.
    Quote Originally Posted by RONA View Post
    Mines will program to your mods as well tho.... probably easier if the car was near a mines tuner tho
  1. Prototype/Programmable 4AG ECU? Anyone know anything? 56k
    By Killswitch in forum Tech and Conversions
    Last Post: 10-04-2010, 01:23 AM
  2. HELP: 1GGTE running slow, Error code 11.. what is it? *FIXED*
    By Jabtronic in forum Tech and Conversions
    Last Post: 31-01-2009, 02:05 PM
  3. Fault Codes
    By Duk in forum Tech and Conversions
    Last Post: 24-07-2007, 09:42 PM
  4. **bad info** 4agze Ecu
    By progkamol in forum Tech and Conversions
    Last Post: 26-07-2006, 05:38 PM
  5. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 11:17 AM
