Rodger,
You may want to take out the "2T-G" out of the subject, as being the twin cam head it would be wider, and therefore closer to the brake booster and master cylinder...
Hi All,
As I have no engine in either of my TA-22s I cannot measure.
So could someone please measure the distance from Cylinder 4 port face to the brake booster and mounting bolt and master cylinder (three measurements), for me.
I need to know how much room there is for ram tube choice on a 2T Redline Manifold/Solex combination. The manifold is 35mm longer than the Mikuni 2T equivalent.
Regards
Rodger
Rodger,
ok well these are only rough measurments on a 2T, they are 210mm,260mm and 270mm respectively, hope that helps
Rodger, if it helps I'll have a 2T with twin Dellortos sitting on a Redline manifold in my Celica by close of this weekend....let me know if you want a pic/measurements
Thanks Skidz it will help.
twentyeight. I could do with the 2T-G measurement for the standard set up as a reference. I understood it is the same but the numbers will tell.
Grega. Yes please. What filter? I have a feeling the ram tubes I planned to use are going to be very close to hitting the M/C bolt. I may have to go with a shorter set.
I need this handy bit of info for reference as I build up a complete bolt on kit.
Regards
Rodger
No worries Rodger...
rodger - i'm using basically a thin filter for a weber wich bolts straight to the dellorto
the filters are made by TFI racing - paper element type : 426-401 is the part number
stay tuned
Hey Rodger,
i have a 2tg with a redline manifold and 2 40mm DDH solexs on it, medium ram tubes to suit and i have fitted ram tube uni filter socks.
i measured:
- face of the solex to m/c = 3 1/4 inches
- face of solex to nut on m/c = 2 inches or 52mm
here is a pic with my cheapo camera.
fonzy
deepdishfactory
