Results 16 to 30 of 31
Thread: how to use 1jz hydro. water pump for power steering
    Junior Member Grease Monkey BMWTurbo's Avatar
    Jan 2007
    Default Re: how to use 1jz hydro. water pump for power steering
    That's a great idea 1jzracing I've retained my power steer pump though as it drives the hydraulic brake master cylinder also But I'd never thought about using the hydraulic pump to drive the power steer
    Whats the feasibility of the hydro pump being used to pump coolant?
    Methinks lubrication would be your problem there. Why would you want to do this though?
    Yeah, lube is what I think would kill it. (lack there-of)
    WTA
    There is probably some additive you can use with the coolant so it doesn't kill the pump... I seem to recall something about this during a discussion about using a fuel pump for water injection, can't remember if it was here or PF though?
    Also I wonder if the hydro pump might move the coolant too fast?
    Hmm, ta, I'll look into it.
    Pump could move it too fast, but I can always control the PWM valve.
    Junior Member Grease Monkey Jasper's Avatar
    Flow rate will be too low, not too high.
    Damn, well there goes that idea.
    I can hook you up with an early model Davies Craig EWP...
    User Conversion King
    NWA
    dragging up an old topic, yes.
    Quote Originally Posted by camrygt?
    yeah I wouldn't have a clue, it worked perfectly for the 10 min test drive.
    As I wound up the speed controller I could here the fluid noise begin like normal power steering does as the air etc gets out of it.
    I'm sure i'll hear about it if anything explodes in the future
    how is this one going after a few months?
    i dont have a power steering pump and i do have a jaycar motor speed controller laying around so this seems like the easiest option
    hello
    Quote Originally Posted by brett_celicacoupe
    Do you have a hydraulic fan pump?
    I just don't see any cars with 1J, 2J or 1U engines in your sig.
    NWA
    Quote Originally Posted by Joshstix
    youd be suprised at the amount of junk in my shed
    http://www.toymods.net/forums/showpo...1&postcount=24
    hello
    Forum Sponsor Grease Monkey
    when i saw the owner it was still working a few months after with no problems and I havn't heard anything from the guy so i presume its all ok
    probably the easier option if you prefer wires
    Ah yes very cool. It will be a bit of an improvement on the old MG that was in the thing.
    Junior Member Grease Monkey toyoda's Avatar
    hey mate are you able to upload those picks up again please
    Pics are still there, but there is a problem with the Toymods database.
    Give it a week and try again.
  1. 4S-FE Water pump equivalent
    By deeps in forum Tech and Conversions
    Last Post: 04-12-2006, 06:34 PM
  2. 1JZ powersteering pump, what fits?
    By beatle in forum Tech and Conversions
    Last Post: 18-07-2006, 06:13 PM
  3. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
  4. run your power steer from hyd water pump!!
    By 1jzracing in forum Tech and Conversions
    Last Post: 26-02-2006, 10:42 PM
