15psi is pushing it with an SC12. If you're going to spend the dollars, I'd got turbo or SC14 if you want that much pressure. As for the rebuild, do it properlly. Get the block acid dipped, new oversize bearings, pistons, rings, new gasket kit, and make sure it's assembled to spec. Also, if you want to rev it hard and hold together, get some ARP bolts to stop things flying apart...Plus the standard stuff, new oil pump, new water pump, timimg belt, etc...
RM.
