There is another type, it looks similar to the type 4 but has allowance for float bowl adjustment on both sides of the bowl top. Only one side has been drilled through on our set.
This type, and also the type 2 carburettor also have the 175 markings for 44mm butterflies.
The type 2 carbies are prone to damaged thread where the venturi locking screws go in as the threaded protruding section are shorter than all the other types. This really sucks!
The type 2 has a better seal between the tops of the jets and the float bowl, other models are prone to flooding over sustained bumpy roads, especially with steep inclines.
The genuine gasket kits are a Solex/Pirelli combined production according to the labels.
The throttle linkages of the type 2 carbies are not interchangable with other models as the locating section is cut on a very different angle (ie. not 8 degrees).
The type 2 has PHH-2 cast into the top from memory.
It should also be noted that some models, type 2 and type (similar to 4) included were available with choke assemblies that operate in the opposite direction to what is required for 2TG/18RG engines, as they were designed to be used on engines such as the datsuns that had their intakes on the left hand side of the vehicle.
The tops and rotors of the choke assemblies from types 1, 2, 3, 4, and the one similar to 4are interchangable to fix this issue.
Some sets of type 3 PHH-40 carbies have idle jets that are too small to service an 18RG correctly, could be all sets, not sure. We bored a larger hole and now they are great.
These came standard on our 88211 manifold.
The type 5 has electronic choke warmers and is reportedly the least preferred version.
The top end gaskets are not similar to any other models and there is no removable sleeve in the outer section of the throat as is present in earlier models (88222 2TG era -type 4).
All the sets I've seen have had their accelleration pumps adjested so poorly that they do not function, spacers were required to get them to squirt at all. Perhaps this is part of why they are so unpopular.
The tube positioning of the type 4 carbies around the throat indicates that they MAY (I take no responsibility for mess ups) be able to be bored out to suit 44mm butterflies.
Note: 44mm butterflies take a different shaft and different screws too.
Another model that interchanges with the PHH, DCOE, SK racing, OER carbies is the Solex ADDHE. These were solex Europe's equivalent model, rather that Mukuni's version.
