what do you need to know? if them looms already attatched to the ecu its mostly done. you just have to wire the altenator which aint too hard and thats about it.
gday im going to be wiring my car tomorrow, if someone could please give me a hand it would be greatly appreciated.
its a 7 ribbed bottom with a small port (blue writing) top. Have full loom with ecu, most of is plugged in and ready to go. But ive become stuck in a few spots.
The motor is in a square head light ke70 that is set up for drift.
I live in buderim on the sunshine coast
0402695213
thanks in advance.
ive wired the alternator already. But ive got some problems with what to do about a fuse box, do i use the old one from the 4kc (goes to starter/m, plugs into some wires through the front quater, and then goes to the positive of the batt). and i was told to buy a 14 pin plug from an sv21 camry for the ecu. Which i did, so i have about 6ish wires hanging around and i dont know what to do with them. I have a wiring diagram and pinouts.
ke70, drift/hillclimb/sprint special
bells AND whistles.
well i used both fuse boxes. i dont know what your talking about with getting a camry plug, i didnt need to do that. i did mine at the start of the year so i dont totaly remeber everything. if you have the diagram you can see what wires you dont need and strip them from the loom to make it simpler. from memory the only thing i did dodgily was wire the fuel pump to a switch cause i couldnt be arsed using the fuel pump relay for some reason.
yeah i intend one wiring it to a relay, and a switch, so noone can pinchy my car. Put it somewhere noone would ever guess.
the reason i had to get a camry plug was i had a loom, but only had two plugs, and the ecu has support for 3 plugs. I was told by the brisbane based company that i bought my motor from when i asked for help regarding wiring, he said i had to buy the circuit opening relay and the 14 (7x2) pin plug that goes into the ecu.
cheers for the fast reply.
bells AND whistles.
hmm ah yes the plug on the right i forgot about that. i also didnt have the plug for it. you need to connect three wires to the slot, pin 1,2 and 8. i just smashed a loom plug i had from something else to get the three wires with the plugs that fit each individual pin. from memory pin 1 and 8 require feed from the ignition while pin 2 requires constant 12v, but you have a diagram so you can confirm that for yourself.
so anyone at all, i can pay with beer or cash, its fricken annoying me, even if you can give me a call and give me some hints and tips.
0402695213
cheers.
bells AND whistles.
ive wired most of it up but still having some dramas, so if anyone is near the sunshine coast i beg of your assistance.
bells AND whistles.
