Results 1 to 5 of 5
Thread: MA71 tailshaft center bearing part # ????
    Forum Contributor Domestic Engineer
    Default MA71 tailshaft center bearing part # ????
    Hey everyone.
    I am after some help chasing down a center bearing for an MA71.
    My 2 local parts shops don't have a listing for it in the brands that they carry, and my toyota dealer says there is no such thing, that it doesn't use one. ( This seems to be their answer to anything that sounds any more adventurous than spark plugs ).
    Surely someone has bought one, or is it a case of ripping the bastard out and taking it to a specialty bearing shop and getting something made up.
    I can't seem to find much through google, but i have no doubt that it is most likely somewhere there.
    Thanks in advance people, as getting rid of that soft shudder under the floor will do a great deal to improve my level of sanity.
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Default Re: MA71 tailshaft center bearing part # ????
    37230-14061 8601-8708 bearing assy, centre support, no1
    37230-14070 8708-8808 bearing assy, centre support, no1
    failing that, mark the shaft with some liquid paper so you get it back in the car in the same position, and remove it and take it to a driveshaft servicing place.
    the trans will spew fluid out when you pull the shaft out, so plug it with a rag.
    or just pay someone to do it.
    good luck
    DAN
    forgot to give you pics of how to do it
    http://www.cygnusx1.net/supra/librar.../pr/PR_03.html
    Sorry, but can you please clarify, are these 2 different parts for different models ( auto and man ), or is that center bearing and flange etc ???? Also, are these the toyota parts, or from some other company??
    Thanks.
    these are toyota part numbers
    they fit both auto and manual afaik
    the 8601-8708 tells you what manufacture date the bearing fits
    so it's from jan 1986 to aug 1987
    and it's only the bearing and holder
    if you look at the link you will see that the centre bearing is seperate from the flange
    find another competent toyota spare parts dealer and they will be able to get you the right one, or as i mentioned remove the shaft and take it to a driveshaft place.
    Dan
    Aaaahhhhh.
    Now that all makes perfect sense.
    Thanks very much, this makes it all much easier.
    + rep.
  1. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  2. replacing axle bearing ??
    By sam-131 in forum Tech and Conversions
    Last Post: 03-07-2006, 07:57 PM
  3. Avante/TA22 rear disks - bearing retainer
    By TwentyTwo in forum Tech and Conversions
    Last Post: 27-06-2006, 03:21 PM
  4. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 08:34 PM
  5. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
