Results 1 to 13 of 13
Thread: 3SGTE Remove Oil Cap = Engine Stalls
    Junior Member Domestic Engineer 1200det's Avatar
    Default 3SGTE Remove Oil Cap = Engine Stalls
    Just been servicing a friends SW20 Turbo and have noted that when you remove the Oil Cap with the engine running its comes very close to stalling and sometimes will ???
    This Normal ?
    Have tried this on all 3 of my 7MGTE`s and nothing changes , Also tried it on my 4AGZE and 22R without these effects !!!!!!
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    has no Toyota anymore :( Conversion King tooch's Avatar
    Default Re: 3SGTE Remove Oil Cap = Engine Stalls
    Hmm it's normal for the idle to drop a bit, but sounds like some serious blowby if it's actually stalling.
    How many km;s on the motor?
    Its had another engine fitted in recent months so no idea on condition or Kilometres , Might be time for a compression test.
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Crankcase is part of intake system by PCV valve, if PCV valve is not working properly can draw in too much air when take rocker cover of giving symptons you are taking about.
    Quote Originally Posted by jonra23
    Makes perfect sense !!!!
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    you've created giant leak in the inlet hose and air is going into the engine via the cam cover breather. The air going is affecting the reading the afm is giving to the computer.
    The last time i ran my engine without a oil cap it flooded the sparkplug valley and make for a good smoke show. Why do you want to run without the cap?
    Dan
    No reason why i would want to , Just something that caused concern
    From your comments and now when i stand back and look at what you guys have said , Its makes sense to why it wouldnt run without a Oil cap
    Quote Originally Posted by c2888
    Dan
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    my 20v 4a wont run with oil cap off, never thought much of it cos it seemed like a good thing to me, stop me forgeting to put it on.
    the other day i ran my 3sgte for bout 5 mins with oil cap removed and it was fine ? the revs didnt change and didnt want to stall ?
    Is your 3SGTE MAP or AFM?
    Afm.........
    whys that ?
    MAP doesn't give a rats if there is an air leak. AFM will because it's "measured" all the air in the system. My 1G will change engine revs and labour a bit with the cap closed. Won't stall though.
    Last Post: 12-07-2019, 05:11 PM
  2. MA70 --> JZA70 Conversion
  3. How to remove Corolla engine ?
    By corolla16 in forum Tech and Conversions
    Last Post: 27-06-2006, 12:49 AM
  4. Cooling Systems - Overheating Problems.
