Results 16 to 29 of 29
Thread: bolting bits back together AKA engine rebuild questions
    Junior Member Backyard Mechanic M.J.H's Avatar
    Default Re: bolting bits back together AKA engine rebuild questions
    Quote Originally Posted by love ke70
    hello everyone,
    well as some may know been rebuilding my 1GGTE
    and anyways, i get it back from engine shop on...early this week and before i bolt all those bits back together i have a multitude of questions!
    now, dad has done some rebuilds in his time..but i wanna double check his theories as he is a bit old and dated these days (god bless him tho )
    now, hes said...wash of the coating on the bearings before you put them in...im down with that
    and also, the next thing is he has this icky tube of thick black shit he calls graphite paste, and says bearings etc should be coated with that and then it gets flushed out once oil pressure buillds....is this true? does andrew need to use the icky black stuff?
    hmm, that should do for now...ill ask more as i get the first questions answered...i have much repping power, so give me your best!
    cheers guys, keen to hear what everyone has to say about anything i may need to know/do in the bolt it back together process...ta guys, andrew
    Just what the others have said re oil the rings and bearings etc.
    Another thing to do is get a clean rag or three and wipe the bores with them before insatalling the pistons etc. Could be a chance they didn't do this at the shop and you don't want any grit in there from the honing etc.
    Another thing is when you install the pistons and the bores etc are nice and lubed with oil and you have tensioned up the big ends etc, Turn the engine over by hand a couple of times. Do this for each set you fit, Eg Fit 1 and 6 then wind over a couple of times then do 2 and 5 etc. But if you fill the oil pump with vas then DON"T turn the motor over after it is fitted or it will not work as well.
    As for the cams i never used the moly stuff before just drowned them in oil before fitting the tappit cover which was usally the last thing before firing it up, Has always worked for me.
    Sorry if I just repeated what others said but it is late, Good luck and happy motoring when it's all going again.
    hello everyone,
    you use soft toilet paper to buff the bearings!
    use assemblie lube on everything, not oil or anything else! assemblie lude sitcks better and if the motor sits for a week or more before it goes in {as in most cases} you need to have a coating which the oil will not do.
    when you get the block back you blow it out with air and clean out the oil gallerys with rifle cleaning brush, then wash it in the hottest water you can get then blow it out with air again and lube the block.
    Thumbs up Re: bolting bits back together AKA engine rebuild questions
    Quote Originally Posted by Lukey-KE20
    You'll also find you put the bottom end together twice. You need to check the bearing clearances with plastiguage before final assembly.
    Luke
    could you explain this further please...im not quite understanding why i have to check bearing clearances if my crank has just been ground to match the bearings i supplied..
    SLIDE - thats my engine haha! i was just double checking that was the oil pump, coz id rather look like a newb first time rebuilding 17 year old then make a mess of this rather costly rebuild...oh wait, i am a first time rebuilding newb 17 year old...owell
    Quote Originally Posted by M.J.H
    why do you turn it over? just to make sure she runs nice and smooth?
    i could fit pistons and everything then add front cover, so i should be able to do it...
    thanks mick! ive been lovin u far too much lately so cant rep you again, but ill make it up to ya
    so ya say to assembly lube it all...sounds like dad may be right after all! sounds right that that will stick better then the oil...and yeah it wont all be done in a day unfortunately
    why do you wash it with hot hot HOT water?
    thanks again to everyone!!!
    hot hot water (boiling preferably) is so that it evaporates off straight away and doesn;t pool, which leads to rust.
    get it clean enough to eat off
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Quote Originally Posted by shinybluesteel
    exactly mate!
    you always check with plastiguage when you get it back! even top machining shops have made mistakes or you or they orderd the wrong bearings etc!
    dont forget to get the crank a big wack on the end with bearing caps on but not tight so you know the crank has seated properly
    Junior Member Backyard Mechanic Lukey-KE20's Avatar
    Quote Originally Posted by kingmick
    exactly mate!
    That's true. You really should check both the machinist's work and that you actually have the bearings that you asked for.
    The reason you spin the crank between installing each rod/bearing is to check if the crank is going to bind. If you can't spin after installing a rod, you know which bearing is the problem.
    Luke
    south australia
    also when cleaning parts dont use degreaser, it leaves residue behind.
    use carby clean, it dries and doesnt leave any residue and cleans stuff real good.
    im talking bout cleaning internal engine parts and the like.
    yeah check EVERYTHING with plastiguage, not just main bearings i do rod bearings aswell also make sure your ring gaps and such are correct.
    also but a tiny bit of oil on any bolts or studs (i mean a super fine coating) just so they dont bind metal to metal when you torque them up casue u can get bad torque readings,
    also check all your bearing and rod clearances at your full torque settings
    ok, whats a plastigauge?
    im guessing its different to feeler gauges?
    deffently, its like plasticine and you put it in between the bearing and crank (when doing main bearings) then tighten them up, then carefuly take them back of fthen measure the thickness which gives you the bearing clearance
    you can do one bearing at a time or the whole crank
    and where would i find this plastigauge?
    your engine machinst should be able to hook you up otherwise ACL make the stuff so bursons or similar
    basically yes.
    Is no good getting it all together then finding that something has gone wrong so check and turn as you go.
    Also lets you check that the rings have gone in the right spot and not slipped sideways a little when being compressed. Had that happen once and had to redo that one.
    Last Post: 12-07-2019, 05:11 PM
  2. MA70 --> JZA70 Conversion
  3. Aftermarket Engine Management - Burning Questions
    By SilverGhost in forum Tech and Conversions
    Last Post: 01-07-2006, 06:30 AM
  4. rn40 hilux engine and gearbox questions
    By vanman in forum Tech and Conversions
    Last Post: 09-04-2006, 06:07 PM
