Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 121 to 135 of 161
Thread: Guide - How to wire up thermofans
  1. #121
    Default Re: Guide - How to wire up thermofans
    wrong wedding...
    Peewee
    2013 86 GTS
  2. #122
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    Dont worry, I just read what was written on page 4, which I had done a good job of missing so far.
    Thanks guys,
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  3. #123
    Is awesome Backyard Mechanic
    Jan 2008
    + reps for you all!
    but i dont think you guys care.
    wired all up and it works first go.
    Now I dont have to top up water every times it cools down anymore! yay
  4. #124
    Thread Dig,
    Im going to wire two EL thermo fans using this diagram
    But how will i wire the second fan without drawing excessive amperage through either of these two relays. ( i plan on using two relays only)
    edit: Also the thermo switch i have is NC
  5. #125
    To answer your question, you can't the way you've wired it up.
    That first relay is pointless.
    Peewee
    2013 86 GTS
  6. #126
    Well i havent wired it that way currently.
    Can you suggest or point to a diagram on how i should wire two thermos?
    Use the second relay diagram twice?
  7. #127
    Use the 2nd diagram twice.
    The first relay there has no benefit, just do the 30 and 85 connections straight to two '87A enabled' relays directly.
    Peewee
    2013 86 GTS
  8. #128
    Actually, I can see why you've done it that way.
    Ditch the NC sensor and get a NO.
    Peewee
    2013 86 GTS
  9. #129
    OK i think i understand.....
    Like this?
  10. #130
    Quote Originally Posted by CrUZida View Post
    I dont really want to ditch the NC sensor.(just got it today at $50 )
  11. #131
    If you want to keep the NC switch, then you'll need to wire that first relay in, otherwise your thermo's will run when you turn the key off, or run 3 relays.
    You can get a 40A relay to replace the 2nd relay (and consequently the 3rd), but some don't recommend it.
    Peewee
    2013 86 GTS
  12. #132
    Junior Member 1st year Apprentice 87lux's Avatar
    Mar 2008
    queensland
    edit i stuff up
    Last edited by 87lux; 05-07-2010 at 09:33 PM. Reason: wrote something that was incorrect
  13. #133
    So umm i dont wanna use three relays cause that would be gay.
    Can i get two relays in one thats weather proof?
  14. #134
    Quote Originally Posted by VA61DETT View Post
    Hi
    chaserbuddy.
    You can always do what I used to do and use one of these to drive you thermo fan relay:
    http://www.altronics.com.au/index.as...=item&id=S5595
    I used to just bolt em on to the thermostat housing with an ally tab.
    Good for a quick & cheep solution
    Just make sure to get the 'Normally Open' type.
    -A
    I tried these and they work better than i thought they would (so far)
    I used a N/O 80deg as above and just stuck it to the top of the radiator with a mix of superglue and heatsink compound
    Setup is a 78deg thermostat, JAR alloy radiator and AU Falcon twin thermo fans
    At the moment the fans are just wired in series (ie, half speed) through a single 30A relay and this seems to be fine for normal driving - they only come on if idling for a period of time (ie long set of traffic lights) and surprisingly the hysteresis isnt too great - on switch off the fans will run for maybe a minute or two which is good.
    Will try wiring in an additional thermal breaker of a higher temp and relay which will switch the fans to full speed
    +rep for this thread!
  15. #135
    Measured the startup current and running current on the AU twin thermos in the Cressida today.
    Startup: Peak current was like 75+amps (limit of this ammeter is 80A but only a very short time obviously), running current was around 19.2A. (This is the combined current draw, i.e. both fans which are currently connected in parallel)
    Video of ammeter during startup and running here.
    http://www.youtube.com/watch?v=9_0xgmAff0U
    Ammeter set up as below. (Cressida is now wired with a single 60A relay, single 40A fuse and wiring sized for 50A). (The 40A fuse was what peewee used originally and has survived this long so I left it)
    And a pic of the tridon thermo switch installed in the thermostat housing (As installed by peewee) Works very well and ends up quite neat.
  1. Replies: 1
    Last Post: 15-02-2009, 09:33 AM
