Results 16 to 30 of 30
Thread: Too big fuel pump maybe?
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    Default Re: Too big fuel pump maybe?
    Thanks for the info. Hey Mullet, I found you can get a SARD reg for $140 on ebay.
    == 4AGZE SC14 Supercharged ==
    Now flogg'n the SC14 @ 18psi....
    yes a chinese copy sard
    Canterbury
    No kidding?! It even says SARD on the box!!! Anyway maybe SARD products are 'sweat shopped' in China anyway? These days business is often dirty in that profit margin seems to be placed beyond anything else.
    o had to fix a prob for a customer that bought one and it wasnt a proper sard! he bought it off ebay and it came with a pressure gauge! i ask you, do you ever see new sard injectors at that reduction in price?
    Yeah, ain't that the truth. I guess when you buy a genuine one though, at least you've got recourse if it fails...I'll call Aston monday if you like, get a firm price, that was just a second handy...
    RM.
    vic
    let us know if your new FPR fixes the problem.
    AE92 4AGTE SX HATCH---- 14.2 @ 99 MPH
    Malpassi are a good reg, you can get them in 1:1 or 1:1.8 rising rate (psi boost to psi fuel). You can get them cheaply from various good sources (ie not ebay). Aeromotive are a good reg as well if you want AN-flare connections. Sard are good, but the genuine ones are expensive because of the jap tuner factor and not much better than a malpassi for flow, etc.
    Current Cars:
    with the 190L walbro (155 at 40psi) i had no issues using a ... 3SFE? pressure reg or a 4AG reg... the 250 is about.. 210-220 at 40psi or similar?
    shoulda mentioned i also put in 8mm lines that prolly helped...
    so is it your lines or your reg?
    i vaguely remember hearing rumours of malpassi's not holding pressure too well, relative to manifold vac/boost.. have you guys with them monitored the rail pressures?
    Most people I've spoken to who have used Malpassi's have told me to stay well away. They're known for being inaccurate, especially when large volumes of fuel are involved.
    I've heard good things about Sard regulators, or if you want to do it on the cheap you could run a stock FPR at either end of the rail, then drill & tap a hole in the middle of the rail for the fuel inlet.
    hmmm, I've only heard good things about malpassi regs, and that was from a bloke who runs a performance workshop here in Wollongong. I figured he knew what he was talking about as he runs a Turbo 6cyl Cortina with an Autronic in the low nines.
    Current Cars:
    Junior Member Domestic Engineer urantia's Avatar
    ooh crap, recomended a walbro 255 to my cousin with a aw11/beams 3sge stock fuel lines, he's not going to be happy if he reads this thread.
    too high of a fuel pressure is going to cuase it to run richer, anything worse likely to happen?
    98 3rz-fe Hilux 4x4
    97 Hiace AWD Super Custom 1kz turbo diesel (sold)
    87 MA70 w/ 1JZ-GTE Manual Conversion GT (moss growing on roof deteriorating away but open to offers)
    Yup, called Jshop, $199 for a SARD FPR. And prices on random goodies: $175 for big-ass china IC, $199 for hi-flow cat...etc
    RM
    Canterbury
    Just though I'd dig this up to share my findings.....
    [img=http://img97.imageshack.us/img97/5725/100kwregdz7.th.jpg]
    I decided to try this regulator a, 2.9 bar, 100kW 4AGE regulator. All other 4AG(Z)E use a 2.5bar reg with banjo fittings for the low pressure reg outlet.I decided to try it because I had a hunch about this being a lot less restrictive outlet style than the banjo bolt system with two tiny holes etc.
    Guess what!! My fuel pressure dropped from around 3.5bar (on the 2.5bar reg) to 2.9 bar @ 14V at the pump with the 2.9bar reg (and down to about 2.5bar at idle). So thats a cheaper fix than a SARD for you guys out there. It cost me $20 for the reg and about $15 for the 3ft of 6.5mm fuel line. Completely bolt on.
    Cheers, Nick
    Canterbury
    Just though I'd dig this thread up to share my findings.....
    I decided to try this regulator a 2.9 bar, 100kW 4AGE regulator. All other 4AG(Z)E use a 2.5bar regulator with banjo fittings for the low pressure reg outlet. I decided to try it because I had a hunch about this being a lot less restrictive outlet style than the banjo bolt system with two tiny holes etc. Guess what!! My fuel pressure dropped from around 3.5bar (on the 2.5bar reg) to 2.9 bar @ 14V at the pump with the 2.9bar reg (and down to about 2.5bar at idle). So thats a cheaper fix than a SARD for you guys out there. It cost me $20 for the reg and about $15 for the 3ft of 6.5mm fuel line. Completely bolt on.
    Cheers, Nick
    Junior Member 1st year Apprentice hybridaddy's Avatar
    Jun 2006
    ive actually seen a car that when the bonnet was shut it wouldnt run.
    open the bonnet made 450hp,close bonnet and it would stall almost magically.
    it turned out that his fuel line was being kinked by a bulge in the bonnet every time it was shut.
    now wheres my marshmallows
  1. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 12:15 PM
  2. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 09:12 AM
  3. weak fuel pump? (1jz-gte lost alot of power)
    Last Post: 23-01-2006, 08:14 PM
  4. Replies: 1
