distributor cap - 19101-88280
distributor rotor - 19104-88280
howdy people i'm trying to get a list of genuine toyota part numbers for the 3t-gteu engine.
So far the only ones i have is:
Coil -- 90919-02117
Throttle Body Sensor -- 89452-14??? (can someone find the last couple numbers)
Engine Block -- 11411-#####
Injector -- 32350-28011
Cold Start Injector -- 22230-28020
Fuel Pressure Regulator -- 23280-28020
Throttle Body -- 22210-280(30) & 195900-0(672)
Head -- 11111-88280
Intake Cam -- 13511-88280
Exhaust Cam -- 13512-88280
Gasket Intake manifold -- 17177-88280
Ignitor --
Distrubutor --
Knock Computer --
EFI Computer --
Sump --
Head Gasket --
Water Pump Gasket --
Thermostat Gasket --
Any help would be get![]()
1 MS55 - 3 TA47 - 1 MS123 - 1 YR21(SR21) - 1 RX80 - 1 ST165 - 1 JZS160
sweet dude.
I should have a few dozen more when i checkout my garage. Can someone get the knock and efi computer part numbers?
I think the part number for the EFI computer is 89561-14190
Simon
http://users.chariot.net.au/~stmezz/celica.htm
Can someone tell me why there isn't a part number on the 3t-gteu crank, thermostat, water pump and any other things?
Also on the throttle body theres two different part numbers can someone explain me why
thanks
because Toyota don't see any logical need to have the actual part number on every item. Thats why they have a parts department, they will work it out for you.....Originally Posted by Jackel
Not sure whta throttle body numbers you mean, maybe they are two separate parts?
Simon
can any get me part numbers for the:
knock computer
distributor
ignitor
It's a little bit hard to see but the computer # can be:89610-14020Originally Posted by Jackel
A pic:
http://www.polkatulk.se/Carina'80/3tgknock.JPG
