I came up with a very simple an easily tunable SC bypass ages ago. You just get a small TB connected to the accelerator pedal and in parallel the SC, and get it to open and close in the opposite direction of the main TB. (check my 30second MS paint diagram)
In response to stockystock and warpspeeds reduced back pressure theory. I disagree. It has been proven time and time again that turbos make power more efficiently than superchargers. This means that the power loss associated with the backpressure of a turbo is less parasitic then the drive system of the supercharger. In a twin charge system where the SC turns off at higher RPM, the backpressure of the turbo can easily be reduced further than in a straight turbo application by using a very large exhaust side on the turbo. There SC will get rid of any lag normally associated with large exhaust housings.
				 Re: twincharging prototypes needing constructive critisism (SC14 + turbo)
