i'll have a look at the gen 3/4 coils, from hazy memory they are denso.
Really? Kinda strage the coils are so cheap then...Originally Posted by o_man_ra23
Originally Posted by ae86drift
Garth - 100% AE86 Addict
AE86 - Levin & Trueno - The Legends Live On!
'AE86' - Toyota Sprinter Trueno GTV
"It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
So the bottom line for all of this is that the maximum RPM supported by a "sequential" setup is double that which can be supported for a wasted spark setup, for any given ignition technology.
One reason to use CDI is if the engine revs are high enough that peak inductor current cannot be reached between successive ignition events[1][2]. This is likely to happen:
- using a single coil + distributor setup[3]
 - if you have a true high-rpm engine[4]
The other reason to use CDI would be for when even a fully charged inductor doesn't store enough energy for each spark. In This case a CDI system, which just uses the coil as a step-up transformer rather than an energy storage device, could help. This is sometimes the case for turbo cars running high boost.
Anyway, for your a low rpm road car engine, regardless of whether you have CDI or not, it probably doesn't matter whether you choose wasted spark or not.
- "Dwell time" is just the time required to charge the inductor. It is not a function of RPM.
 - Google for "inductor transient response" if you want to understand what is going on.
 - The problem gets worse for engines with more cylinders.
 - Not likely in a road car, but maybe in a race car or motorcycle.
