Er ...... was just trying to see if that caused anyOriginally Posted by oldcorollas
knocking when taking off. I don't have a timing
light, so that was basically an estimate. Can't
do static timing either with an electronic dizzy.
As Toycrash mentioned, using the boltperhaps by using a bolt to fill the "hole" you have left open the internal passages and it now doesn't work how it should?
shouldn't cause any problems, since there
is not supposed to be any vacuum emitting
from that hole. I believe the solenoid is just
meant to cut off the idle jet when stopping the
engine. But I will replace the solenoid and see
if there is any improvement, just in case.
Both vacuum stages on the distributor appearyou should check the operation of the vaccum pots on the dizzy, and then set as per normal.. check where the vacuum source is on the carby too.... manifold or ported vacuum?
to be functioning, but I think the advance is
insufficient. Both stages must be connected
via a common T-joint, connecting either stage
alone does not seem to produce any advance.
Seems like a very odd diaphragm design.
The vacuum source on the carby is the normal
ported inlet just on top of the throttle butterfly.
start by ACTUALLY checking the advance and vacuum mechanisms of the dizzy... then clean the carby properly.. if you don't know how to, then it's time to learn
if the carbvy has been sitting around for too long, it might be stuffed.
you should at least open it up and check the main jets are not blocked, and the power valve works correctly...
etc[/QUOTE]
I'm getting it taken apart and cleaned soon
as I can. I've bought a repair kit.
Just to give any example of the level of
expertise in carb cleaning in Malaysia, I asked
this younger mechanic the other day if he
could do it for me. He replied in the negative,
explaining that a carburetor is a very complex
and sensitive unit, and it shouldn't be opened
up and messed around with if there wasn't
any major problems. He said he had seen cases
when carbs were opened up and cleaned,
then on reassembly and reinstallation, the
exhaust gave out white smoke on running ......
Another mechanic told me he had to reassemble
back completely disassembled carburetors,
brought in by car users. They had taken their
cars earlier to other not-so-proficient mechanics
to have the carbs cleaned, but who did not
know how to reassemble them back properly
after taking them apart.
Thanks.
