Most instrument clusters don't run off ecu's.
They run directly off sensors.
Only very new cars have the instruments off the ecu.
is it possible to use ae111 instrument cluster on ae101 ecu?
AE111 could be late enough to be a pain - if you can find some diagrams (walk into a friendly toyota spare parts counter and ask them (very nicely) if you could look at the wiring book for the car) and the cluster has an MPX (or MPX1 or MPX2) pin or pins on it, forget it...
Otherwise, as Cruzida said, it should be no problem but YMMV...
Mos.
would anyone have the pinouts for the ae101 cluster. need them badly. can't find anything on the net or the forum
cheers Mike
If you have the cluster you have the diagram.. (and pinout...)
Most clusters (IIRC AE101 is no different) have enough labels on them to be able to use them without needing any reference material.
Which bits are you not sure about?
Mos.
just need to know what the abbreviation correspond to like fuel, sleedo, tacho, temp.
Most of the cluster lights I have worked out, kinda. ill post up what I have when I get a chance so that some one can check it and tell me that I am wrong.![]()
Cheers mike
Things like fuel, tacho, temp, speedo will have a power pin (IG+ usually), an earth pin (GND or similar) and the signal pin - respectively FU, IG-, TU, SI (sometimes), 4P (output from speedo, designation varies).
The earths and powers may be connected together or may be supplied separately from the loom.
Does this help?
Mos.
helps heaps,
cheers Mike
i have seperated the connections in to 3 banks/plugs, each one numberd as appears on the back of the dash labeled from left to right.
photo Updated, now viewable
B1
01 - na
02 - ground/earth ???
03 - Backlight power/sc-chg(-) ???
04 - ground, sc led ???
05 - abs light
06 - na
07 - na
08 - oil light
09 - battery light
10 - exhaust heat warning light??? (looks like a Catlyc with heat coming off it)
11 - tu (water Temp)
12 - te ???
13 - ig (tacho signal ???)
B2
01 - in ( back of speedo ???)
02 - p4 (speedo pulse out or in ???)
03 - na
04 - na
05 - na
06 - door light +
07 - door light -
08 - seatbelt light
09 - handbrake light
10 - GE ???
11 - supercharger led
12 - P (tach pulse ???)
13 - highbeams +
14 - highbeams -
15 - r indicator
16 - l indicator
B3
01 - fuel reserve light
02 - na
03 - na
04 - fe ???
05 - fu (fuel Level)
06 - na
07 - na
08 - hazards
09 - engine light
10 - demister light
11 - na
12 - na
13 - na
this is what i have so far, the ones with the ??? i am unsure about. could some one fill in the blanks or errors that i have made. the ones that say "na" are not connected/used.
cheers mike
Yep, very bad cameraOriginally Posted by mikie
B1
Not sure - ground or earth would be white/black or brown on the loom - what components does it go to?
Not too sure, but there should also be a charge light somewhere? Is that it?
10 - exhaust heat ??? (looks like a Catlyc with heat coming off it)
Don't worry about that. Exhaust overheating warning light (EGW) - you need the sensor fitted in the exhaust for it.
13 – ig (tacho signal ???)
There's no - or + there? If it goes to the tacho pcb, and ground and power are fed through other pins it could be the tacho signal - wire colour most likely black.
B2
Could be pulses into the speedo.
Could be pulses out of the speedo.
10 – GE ???
Not sure off the top of my head...
Not ringing any bells either, sorry - what component does it run to?
Do you have the loom for this? (If so, have you traced where any of the unused wires go?)
Mos.
previous post updated....
no loom, still need to find plugs somwhere.
GE and IG ar common around the back of the cluster, so i doubt that it will be the tacho pulse
P runs to the back of the tacho
cheers mike
