Results 16 to 30 of 32
Thread: turbo+TVIS
    Default Re: turbo+TVIS
    Depends on what your piping is like as to whether you'll have clearance issues after you've remove the TVIS plate. It's about 12mm thick, so it's not incidental.
    Facebook | LinkedIn
    GT-Four Pilot Backyard Mechanic SilverGhost's Avatar
    Quote Originally Posted by stradlater
    when it comes to the top mount interwarmers on th 3sgte that space is vital. dont know about other motors though
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    yeah 4age, just took a look at it then.
    thanx guys
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    Toymods Club Member Backyard Mechanic Big T's Avatar
    If you plan on completely removing the TVIS plate, you will need to run another spacer in it's place. The "welding" you mentioned takes place between the 3rd and 4th valleys in the intake manifold. There is just not enough surface area to create a decent seal and you'll get vacuum leaks.
    Have a look at the TVIS plate and you'll notice each side has a different face. You'll need to replicate these sealing faces when making another spacer. I have heard of guys simply sticking the 2 gaskets together and having no problems but it's honestly not much hassle modifying the standard TVIS plate to work. As Ghetto said, just remove the shaft/butterflies and weld/epoxy the holes up.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Jun 2006
    so if lookin to get a big port inlet to convert my gze to gte i would need the TVIS plate? or can i get away with not using it and just bolting the thing on without spacer?
    Low rep Grease Monkey
    S.A
    When I did my AE82 4AGTE Conversion, I completely took the T-Vis plate out and the manifold bolted straight back up to the head. No problem!! I also gave the inlet runner a bit of porting before I bolted it up aswell!! Works a treat!!
    Jun 2006
    thanks for the info buddy!!! cheers!
    S.A
    No problem buddy!!
    lol just a funny thought! you can neutral rep each other
    Quote Originally Posted by nos4ag
    How much boost were you running in this setup?
    Eddie.
    S.A
    I am running 7psi for standard everyday driving. I havent turned the boost up yet though.
    But I thought that there was no need for me to have the T-Vis anymore as there would be nothing controling it anymore.
    Aparently if I had welded the holes where the butterfly rod went through the T-Vis Manifold then I would have technically longer inlet rinners, which APPARENTLY would have given me a bit more HP. But ah well! Can anyone confirm this at all??
    ^^^ What's the bet that if you turned up some serious boost you'll start developing leaks? Like i said, there are guys i know that have done this without a problem but the possibility for leaking is too great for my liking. Do it once, do it properly
    Eddie.
    S.A
    Where would the leak be coming from buddy???
    I HAVE done my conversion properly aswell.
    It'll be between the 3rd and 4th valleys in the intake manifold. Just not enough sealing surface on the intake to head without the spacer. I researched this when i was building my motor and it seemed to pop up in passing but without much in depth detail. After digging a bit deeper, 2 separate sources confirmed it WILL leak without the spacer when chasing higher boost.
    The 1st guy runs a turbo 20v with 300+rwkw (his previous engine was a turbo bigport), the other has a 180+rwkw bigport.
    Eddie.
    Jun 2006
    nice guys heaps of info
    :thumbs: cheers!! also i have afm gze without dizzy and would like to know apart from differences in fab work for turbo intake. would it be beneficial to get a map sensor and a map gze ecu and use that? mate has his ae92 with gze lsd turned gte runs 8 psi low and 13 psi high anymore fuel cut makes it no fun. ive currently got his car under the house in pieces to clean it up for him while he's overseas. gettin it ready for sale. and would the afm gze comp run the dash cluster from a carby ae92??
    Last Post: 03-05-2009, 06:47 PM
  2. Boost Leak Tester
    Last Post: 01-06-2006, 11:25 AM
  3. Damaged turbo
    Last Post: 28-04-2006, 07:42 PM
  4. TVIS or not to TVIS...
    Last Post: 12-01-2006, 06:46 AM
