Results 1 to 3 of 3
Thread: MX83 Cressida (with 1JZ) Headlights - issue with high beam
    Default MX83 Cressida (with 1JZ) Headlights - issue with high beam
    Hello forums,
    After all these years, I have another little problem for the group wisdom to solve ...
    My MX83 Cressida (with a 1JZ, thanks to Toymods) has lost its high beam headlights. Symptoms:
    Low beam - working fine
    'Normal' High beam - darkness
    'Flash' High beam - high beam works both sides (for so long as you hold it on 'flash')
    Blue 'High Beam' indicator in cluster - lights up as expected for both 'Normal' and 'Flash' high beam
    When this first happened, the darkness would last maybe a second, then the high beams would light. Then they seemed to be working okay for a while, but now its total darkness.
    The red headlight relay under the bonnet (fusebox behind the battery) clicks when the lights are switched on, but that's it. Is there a different relay for 'Flash' and 'Normal' high beams? Is there something else I'm missing here?
    Thanks in advance for any help or ideas.
    Adam
    '93 MX83 Cressy with 1JZGTE (now with engineered goodness)
    '85 YN57 Hilux SR5 with 3.8l V6
    '98 ES300 (with gold bits!!)
    + A Corolla and some non-Toyotas
    Default Re: MX83 Cressida (with 1JZ) Headlights - issue with high beam
    Okay so maybe I'm the only one to have had this problem so far??
    Well at the risk of talking to myself (but for the benefit of future searchers), I discovered the source of the problem. It was the headlight switch in the steering column.
    There are no headlight relays, beyond the red/brown one in the engine bay. Instead, the full current for the high and low beam are switched in the steering column. Sounds dodgy to me, but to be fair the switch contacts look just like relay contacts. So, I guess they do the job - until they build up a coating of oxide after 30 years of switching.
    The fix was to remove the 'combo' switch (it also does the indicators), prise off the cover and clean up the contacts. I did this in-situ to avoid unpinning the switch from the wiring harness. Once you get the steering wheel off, the combo switch is on the backside of the steering column switch assembly (along with the wiper/wash, headlights, cruise etc). So, you have to unscrew the whole switch assembly to get at it - its only 4 screws though. 4 more screws releases the combo switch. The combo switch has two inner compartments - the indicator side is full of conductive grease, while the headlight side is dry. As you take the lid off the combo, carefully remove the indicator switch and its contact rail and put them to one side. This saves them falling in the dust while working on the switch. The headlight contacts are fixed firmly in place.
    This guy describes how he did this job on his 4Runner, which gives you the idea. Instead of a file, I used 10mm strips of wet & dry, folded in half lengthwise. I used 600 followed by 1200 grit, then sprayed it with contact cleaner to wash away the filings. A quick check ensured that it was in fact working before reassembling everything. Don't forget the indicator switch components!. Reattaching the combo switch, the switch assembly, steering wheel, covers, etc. is just the reverse process. Good as new :-)
    Maybe this will help someone else who faces this issue in the future ...
    Adam
    Jul 2021
    Damn, I thought you were saying you had the jzx81 headlights on your cressida lol. Great writeup however.
  1. Cressida MX83 Rear Too High
    By Cuthbert in forum Tech and Conversions
    Last Post: 04-02-2010, 05:24 PM
  2. MX83 Cressida AC Fan Speed on constant high, Help needed
    By mamba in forum Tech and Conversions
    Last Post: 31-01-2010, 01:08 PM
  3. 1jz into MX83 Cressida A340 Issue
    By brady89 in forum Tech and Conversions
    Last Post: 16-01-2010, 05:41 PM
  4. Disconnect high beam switch / high beam
    By monkeymajik in forum Tech and Conversions
    Last Post: 27-11-2007, 05:31 AM
