Results 1 to 2 of 2
Thread: 3SGE Poor Idle and Engine Dies @ 2500rpm
    Default 3SGE Poor Idle and Engine Dies @ 2500rpm
    Hi All,
    Just gone through a week of doing work on my 92 3S-GE MR2, doing a whole lot of maintenance to fix oil leaks, replace timing belt and clutch. But throughout trying to resolve an issue where it is hard to start, won't idle, and dies/stalls at 2500rpm and won't recover.
    Working through it, the dizzy cap and rotor had a lot of pitting, so I thought I'd found my problem, but once all back together it is still there.
    What I've done is:
    New timing belt
    New clutch
    New crank seals and oil pump seal
    Injectors cleaned and tested
    New dizzy cap and rotor
    New leads
    New plugs
    Tried another TPS
    I'm totally stumped as to what the problem might be. Anyone got any suggestions?
    Kind Regards
    Nathan
    27.90s @ Esses Hillclimb
    Dec 2008
    Wellington, NZ
    Default Re: 3SGE Poor Idle and Engine Dies @ 2500rpm
    Sounds like a fuel supply/pressure problem. You need to check the fuel pressure in the rail and then check the flow OUT of the FPR (return to tank side) by using a spare bit of hose and running the fuel into a clear glass bottle. Get someone to crank the engine briefly (or just turn the ignition ON if the pump primes) and make sure there is a strong jet of fuel into the bottle. Keep a fire extinguisher handy
    Cheers... jondee86
  1. 3tgte idle poor with electrical load
    By pauljones1976 in forum Tech and Conversions
    Last Post: 21-03-2010, 07:16 PM
  2. ISCV Cleaning (*May* solve poor/erratic idle)
    Last Post: 31-08-2009, 12:57 PM
  3. 3SGE BEAMS red top ISCV - engine idle RPM unstable
    By kanazai2001 in forum Tech and Conversions
    Last Post: 07-11-2007, 12:29 PM
  4. Replies: 9
    Last Post: 21-03-2006, 10:41 AM
