Results 1 to 4 of 4
Thread: Replacing 2t/3t cam bearings issues during rebuild
    Aug 2009
    Default Replacing 2t/3t cam bearings issues during rebuild
    I have read a number of forums where it is warning against replacing cam bearings, particularly in U.S sites. They claim you won't get the cam in without machining the shells, I presume they mean honing. Anybody had this issue? I have a new Crower cam to install.
    Sep 2007
    Georgia
    Default Re: Replacing 2t/3t cam bearings issues during rebuild
    The correct cam bearing have to be ordered because there are undersized bearing for this application but finding them are like hunting for hens teeth. When this engine was new, those bearing were available for purchase.
    That said, the standard bearings would need to be measured as well as the cam journals prior to honing the bearings. Now the old trick of cooling/freezing the cam prior to installation. In theory the camshaft would clearance smaller due to the metals reduction due to the cooler temp...
    Sometimes best to let the machine shop perform that procedure.
    https://www.youtube.com/watch?v=omyB6asi3o4
    Aug 2009
    Quote Originally Posted by 73GTV View Post
    Thanks for your info. I will be letting the machine shop fit the bearings, I already bought a set from U.S, just hope they fit correctly. If not they can order a set to suit.
    Sep 2007
    Georgia
  1. Replies: 8
    Last Post: 02-11-2013, 05:49 AM
  2. CT26 turbo rebuild issues
    By punkture in forum Tech and Conversions
    Last Post: 24-09-2010, 04:26 PM
  3. Replacing bearings with engine in car
    By Talasas in forum Tech and Conversions
    Last Post: 17-05-2010, 04:47 PM
  4. replacing MX83 front wheel bearings
    By mamba in forum Tech and Conversions
    Last Post: 04-01-2010, 07:21 AM
  5. replacing ta22 rear wheel bearings
    By Frankhead in forum Tech and Conversions
    Last Post: 09-06-2009, 08:55 PM
