Results 1 to 3 of 3
Thread: 2WD gearbox for 1VD-FTV
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default 2WD gearbox for 1VD-FTV
    Spitballing the idea of a 1VD-FTV in a RWD application but trying to find whether there is a suitable gearbox out there. The VDJ79 uses a H151F and for all I know this gearbox was only used in 4WD applications. Is there a RWD H series that might work behind this engine? Even if it has to be a combination of several gearboxes I don't care. Found reference to the Coaster using this transmission but I cannot find any info on it.
    I just think one of these in an old school 2WD truck would be the bees knees.
    And before you all say it, yes I am well aware of the costs involved. At this stage I'd just like to know if the above can be achieved at all.
    Jun 2010
    Default Re: 2WD gearbox for 1VD-FTV
    The coasters or dynas that were fited with 1hz/1hdts might use a variant of the H15x series box that would give you a straight rwd option if you could swap the rear housings/output shafts out. Have you seen a H15x box without the transfer case on? it may not be to hard to build some sort of carrier for a output shaft if your keen
    May 2006
    I have been looking at the Dyna/Coaster offerings. It seems they use something quite different to the H series gearboxes we know of in the Cruisers. The bellhousing bolt up may be promising but I'd have to get hold of one to see. The rear section however looks very different so I doubt parts will mix and match. The bus gearboxes are all remote shift too, nothing direct on the floor. A 1VD in an old truck with column shift would be pretty damn cool though
    I might just have to stick to going with a 1KD-FTV instead.
  1. T50 gearbox kit
    By Morry Stu in forum Tech and Conversions
    Last Post: 31-08-2014, 11:45 AM
  2. TA22 2TG Remove motor with gearbox or without gearbox?
    By rmwood7 in forum Tech and Conversions
    Last Post: 17-03-2012, 02:59 PM
  3. hiace gearbox conversion problem. gearbox way too small
    Last Post: 28-12-2007, 12:59 PM
  4. P51 Gearbox How you tell?
    Last Post: 21-10-2006, 02:18 PM
  5. Corona gearbox and IS300 gearbox are they the same??
    By amichie in forum Tech and Conversions
    Last Post: 09-06-2006, 06:10 PM
