Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: Dyno in third gear? ( W58)
    Default Dyno in third gear? ( W58)
    Just recently realised that the clown that dynoed my car did it in third gear (according to the graph).
    Woudl this give me a higher reading or a lower reading than is realistic?
    Facebook | LinkedIn
    livin on the edge as a Grease Monkey Snyper's Avatar
    south australia
    Default Re: Dyno in third gear? ( W58)
    who knows... from my experience you can never trust a dyno for figures, only good for a tuning tool.... I have seen power runs done in 2nd, been to another w/shop and they use
    3rd, and another one has used 4th....
    have also seen a car on 2 different dyno shops in one day, and 23kw difference.
    as for the gearing I think it just works the car a bit harder.... depends on how fast they can make their dyno go...
    Brendon
    wasn't my experience, but thanks for the input
    Facebook | LinkedIn
    4th gear is usually what most places use to dyno car,
    try put ya car on car and just do 2nd gear, is very high reading, not sure bout 3rd but yeh they should really use 4th gear, unless your 3rd went out to 200 kms ?
    4th gear is 1to1 or very close to it in most cases! you dyno a manual car in 4th!
    like jorrs said, 4th gear is what should be used.
    They would do it in 3rd if your car exceeds 200km in 4th, but the dyno would have to be calibrated to suit 3rd gear, as using 3rd gear will throw out the readings a bit(this will give you alot higher reading than you should have)
    This is the way the dyno guy explained it to me, but others with more knowledge of dynos might like to back me up or correct me ?
    Ouvea - "The Island Closest To Paradise"
    but if you dyno a manual car in 3rd or 2nd, do you get a higher or a lower reading?
    I thought lower, cos if you went to OVER drive, (5th) THEN you would get a higher reading, becuase THEN it's 0.7:1 or something like that.
    Facebook | LinkedIn
    I would go in excess of 200k's in 4th I think, if it was pushed.
    Facebook | LinkedIn
    it definately gives you a higher reading when dynod in lower gears
    Interesting,
    I would have thought the gear choosen would be the one to give you the least drive train losses and since most 4th gears are 1:1, locking the input shaft to the output shaft, most dyno shops would choose this gear when doing a power run.
    I also thought the idea was to run the car up first, under no load to calibrate the dyno to the revs the car showed thus allowing for different tyre/wheel size, diff ratios and gearbox ratios.
    With that thought, I'd say apart from different drive train losses in each gear, the power reading should be the same.
    I'd also like to think a good tuning shop should be using the dyno like driving on the road. Tuning the car for the whole range of loads and throttle positions, revs and speed.
    Regards
    Rodger
    New Zealand
    Torque at the wheels (which is a bullshit number anyway) will be different, however assuming they put in the correct gear ratio factor the horsepower should be pretty much correct. As long as they are consistent between runs though it won't really matter, same as two cars running the same setup but different diff ratios. As long as its adjusted for the results should be pretty much the same.
    Callum
    yeah, but how they gonna know what the gear ratio is?
    Facebook | LinkedIn
    thats why they usually just run most cars in 4th gear, for consistency, as a car can be run in 2nd or so and put out much higher readings as in power to wheels, thats how dyno guys explained it ?
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    I might be wrong but Im seeing most of the replys pointing towards the dyno guy stuffing up.
    Am I correct ?
    Forum Member Domestic Engineer Nark's Avatar
    ACT-ish
    Yep. Lower gears have higher torque multiplication.
    4th is chosen for consistancy. Most 4th gears are 1:1, that's why it's chosen.
    Max
    NB8B MX-5 | Fulcrum-tuned Tein SS coilovers | Weldwell Engineering 4 point Rollbar | DBA 4000 slotted rotors | Goodridge braided lines
    MY11 Skoda Octavia RS wagon | 2x ISOFIX seats | Iggle Piggle's blanket | Some breast milk stains
  1. Classic celica suspension TA23
    By WindeX in forum Tech and Conversions
    Last Post: 12-01-2007, 09:54 PM
  2. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 01:32 PM
  3. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 11:46 PM
  4. std altezza 3sge on chassis dyno
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-12-2005, 01:06 AM
