These CoPs have a weird plug engagement in that they dont use a normal clip, just a spring that presses on the top of the plug
Yes this is a bit ghey. The other thing is that the UZ tube depth to the top of the spark plug is about 5mm more than what it must be on a 2AZ, the result is that when you fit one the spring is barely contacting the spark plug - not good. So this needs to be sorted. The plug boot comes off (as above) and the spring can be seen, this is just a press fit into the end of the unit and pulls out easily.
Options are to fit a longer spring or stretch the existing one. I buggered about for a while with other springs that didnt quite fit, in the end i ended up just stretching the existing spring, in the above pic you can see one i have stretched. Time will tell if this provides a good enough contact or not.
Once the spring issue is sorted and the plug boot back on the rubber seal can be fitted, this actually fits against the cam cover better upside down and stretched around the "disc" part of the CoP as can kind of be seen here
I think this will give a pretty decent seal against water and shit ingress, unless you are regularly hosing your engine bay/driving through rivers
			 1UZ Coil-on-plug conversion
				 ) because
) because
