Results 1 to 11 of 11
Thread: 4AGE coil on plug conversion
    Chiba
    Default 4AGE coil on plug conversion
    I was just reading through the 3SGTE coil on plug conversion thread, and am now wondering as to the possibility of adding the same system to my 4AGZE.
    Does anyone know of a compatible swap? I plan to be using the Microtech ECU with the X4 ignitor box, so I don't need coils with inbuilt ignitors.
    I'm pretty sure the centre 'valley' cover between the cam covers is lower on the 4AGZE, but the cam covers can be swapped to the 4AGE if extra room is needed.
    Anyone know anything or done this before?
    Default Re: 4AGE coil on plug conversion
    Kaizen Garage use the newer 1NZ coilpacks on 16V's and 1zz coils on 20V's.
    On the 16V you just make a plate for the coils to bolt up to.
    北海度
    A work mate just got a set from the US for his MX-6...
    apparently they have ignitor and coil built in.
    he's gonna use them with an adaptronic in a wasted spark config wired directly from the ignition outputs.
    I've got an adaptronic to go in (one day) and will be looking at that option... (wait till he does his) they look the right fit for a 4AG.
    Chiba
    Tell Me The Details!!!
    senior backyard mechanic Grease Monkey legend's Avatar
    x2 would like to do that mod
    thankyou
    Junior Member Grease Monkey _FNQ_rolla_'s Avatar
    make that 3 now ..........
    please do tell
    they look like the nissan coilpacks
    Aug 2006
    success 6164
    Quote Originally Posted by legend
    could also be 1zz-fe coil packs.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    the ones pictured are not 1zz coilpacks.
    Aug 2006
    success 6164
    this is true, i think there is even the Nissan badge on the number one coil pack..but i definitely know you can use 1zz-fe packs.
  1. 3SGE TPS Loom Plug Onto 4AGE Loom???
    By newbien in forum Tech and Conversions
    Last Post: 12-05-2008, 09:50 PM
  2. 4ac ----> 4age conversion what exactly do i need?
    By 88rolla in forum Tech and Conversions
    Last Post: 26-05-2006, 11:33 AM
