Grease Monkey
tips on removing instrument cluster ms112-help
i have just tried to remove the instrument cluster on my old crown 81. nearly ended in tears,... does anybody have a tip on how to dis connect speedo cable. I need to change some blown bulbs on the warning lights and relace the background light globes as they are very dim. got the front cover off but could get to the speedo cable
please help
Re: tips on removing instrument cluster ms112-help
Disconnect the speedo cable at the gearbox end... then you should be able to pull the instrument cluster (and speedo cable) out far enough that you can undo the speedo cable from the cluster.
Grease Monkey
OHHH of Course cheers I will give it a crack on the w/end
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
