Hello everybody,
I have my car working (it starts) after swap, but I don't have RPM info so I check ECU diagram and I find the PIN for TACH: C-27. It's a black wire with double dot (Black--).
To check that output signal, I start the engine and check with multimeter/voltimeter and oscilloscope, but there isn't any signal.
Please, anybody could help me?
Thanks in advance![]()
use any LED in series with a resistor (say 1k Ohm) and try all pins of the two body loom plugs
Both for positive and negative pulses
Should take under 10 minutes
