Results 1 to 3 of 3
Thread: 4 spot front caliper options 89mm mount
    Aug 2015
    Default 4 spot front caliper options 89mm mount
    hi,
    hoping that the 'brains trust' can help me out
    looking for info of 'high mount' calipers in the 89mm mount spacing.
    trying to find the something with a bigger radius than say a s13wb, or s12 etc
    dimensions would be great the "E" measurement for comparison and the offset from flange to centreline of rotor
    regards
    Jul 2012
    Default Re: 4 spot front caliper options 89mm mount
    88.9 is usually he size, its a metric measurement of imperial 3.5 inch pcd caliper. Theres a lot around. Even in Toyota, I think xt130. Lots of aftermarket ones, eg:https://www.apracing.com/product_det...nted_disc.aspx
    Aug 2015
    Thanx for that
    yes i was aware of the bastardisation of the 3.5" spacing
    I currently am using s13wb calipers but am wanting to install larger diameter rotors and am hoping find calipers with a larger radius, preferably like the upgrade i did 15+years ago on a MX73 when i installed the ijTurbo and bolted on the TT calipers and used the 32mm x ~300 hats over the mx73 hubs
    regards
    rob
  1. 4agze top mount vs front mount
    By Saki in forum Tech and Conversions
    Last Post: 02-10-2011, 10:26 PM
  2. Replies: 3
    Last Post: 19-02-2010, 09:29 PM
  3. twin piston caliper options.
    By MR22ZZ in forum Tech and Conversions
    Last Post: 13-09-2006, 04:52 PM
  4. Replies: 36
    Last Post: 29-04-2006, 08:50 PM
