Originally Posted by
sprinter86
I am not sure if my experience is of any help,
But when I fitted my 264/264 cams, i had a similar issue where is seemed the dizzy could not be put on any tooth that would work.
I decided to use a dial indicator on the cam buckets in order to dial them in to the HKS specification on the cam card,
because the distributor runs off the exhaust cam, adjusting the lobe position via the adjusting cam gear you are also changing the
ignition timing of the engine via the distributers position.
Once is was dialled correctly, it fixed the problem of not being able get the dizzy onto the 'right' tooth.
May or may not be the issue your seeing.....but seemed relevant!
