Results 1 to 3 of 3
Thread: BRAKE UPGRADE questions
    Aug 2015
    Default BRAKE UPGRADE questions
    HI,
    has anyone used the L/C 80 series 32mm caliper with a 28mm rotor?
    everything bolts up OK but i am concerned that the piston travel will be too great with worn pads? can pad 'fall out' or can pistons go past their travel limits and leak with dire results?
    regards
    rob
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Default Re: BRAKE UPGRADE questions
    HI,
    If your worried about the pistons coming out, which it appears you are, you will need to take up the extra space.
    Get some 2mm steel shims waterjet or plama cut in same profile as the pad, if they are indeed the pads i thing they are, they are held in the 4 piston caliper with 2 pins so you don't need to worry about the pads or shims falling out.
    I hope this helps.
    Cheers, Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
    Aug 2015
    thanks peter for the reply. mirrors my thought exactly im now actually investigating the LR110 Calipers as they use a 46mm x 4 caliper same as xjs jag ad im also hoping will have an increased radius of ~14mm coupled with hummer ser3 rotors
  1. TA22 Getting too hot. Cooling System upgrade questions
    By Ashh in forum Tech and Conversions
    Last Post: 17-12-2012, 03:50 PM
  2. ra28 w brake issues(r33 brake upgrade)
    By bigmat in forum Tech and Conversions
    Last Post: 18-12-2008, 07:18 PM
  3. Hoppers Stoppers brake upgrade vs Pug/Lux/Corona brake upgrade
    By ThaNav in forum Tech and Conversions
    Last Post: 04-10-2007, 01:31 PM
  4. RA-23 brake upgrade
    By Petes77celica in forum Tech and Conversions
    Last Post: 08-08-2006, 11:42 AM
  5. Fuel Upgrade for a 1ggte Questions
    By Axerus in forum Tech and Conversions
    Last Post: 24-07-2006, 05:27 PM
