1. 3A bell housing does not bolt up to a 4A engine. You will need to find a 4A bell housing to suit the T40 gearbox.
2. Pass
3. If you mean that you want to use open velocity stacks without the airbox, then you will need to convert to a MAP sensor engine computer as the ST uses a MAF system which nees the factory airbox to work.
4. You will need to upgrade to an EFI fuel system with high pressure pump and return line. Also convert the engine to a RWD style coolant piping system along the lines of the conversion kit available from SQ Engineering. Make sure you have sufficient space for the distributor to clear the firewall, and make sure that you get the engine wiring loom and all sensors/accessories with the engine, or you will spend a lot of time looking for the missing parts.
Cheers... jondee86
				 4age swap to carina AA60
