Results 1 to 5 of 5
Thread: JZA80 Suspension setup
    Penrith BC
    Default JZA80 Suspension setup
    just thought id pass this on...
    got all the numbers tweaked on the car today, and yeah, pretty awesome to drive. not been tracked yet, so take these numbers only as a guide for an agressive street setup. caution, due to the lack of toe, it is less able to pull straight on the freeway and requires a bit more effort to drive, but cornering is sensational
    front:
    camber: 1.5deg
    caster: 5.0deg
    toe: zero
    rear:
    camber: 1.3deg
    toe: zero
    i started with the numbers suggesting in the attached hi perf imports (2000) whiteline article, and then pushed things a little further. am very very happy with it.
    ill update once the swaybars and new shocks/springs go in
    ed
    ../delete/ban
    tech moderator
    Default Re: JZA80 Suspension setup
    I must say I've noticed you all over the Supraforums lately, took me a while to figure out Corona had bought your MA61 and you had a JZA80 That's a good article too, thanks
    Penrith BC
    ../delete/ban
    tech moderator
    Penrith BC
    edit:
    current geometry - updated form above specs
    FRONT:
    camber: -1.7 (-1deg,40min)
    toe: 0.0mm
    caster: +6.2 (+6deg,10min)
    king pin: +11.1
    inc angle: +9.4
    NOTE: this is the MAX available caster/camber combo that the stock setup will allow
    REAR:
    partial toe: 0.5mm
    toe: 1.0mm
    thrust angle: 0
    ../delete/ban
    tech moderator
    Penrith BC
    and another thing with springs...
    after having a few issues with front inside lift off, ive upped the rear spring rate to the same rate as the fronts to reduce weight transfer up that end.
    i probably should have some springs made, and will eventually do that, but for now, the increased rate is pretty marked improvement..
    ed
    ../delete/ban
    tech moderator
  1. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 12:06 PM
  2. Suspension for dummies
    Last Post: 13-09-2007, 08:38 PM
  3. Suspension Questions - with pic
    By Pearce in forum Tech and Conversions
    Last Post: 23-11-2005, 07:57 AM
