when i removed the standard probe from mine. . . i had some problems - in that the ECU doesnt know coolant temperatures. . and hence runs the wrong mixtures once the car heats up. . . .
the ECU relies on the coolant temperature to the set the cold start mixtures, timing and whatever else needs adjusting for cold start.
Try it yourself and see. . . im pretty sure the top one (closest to the thermostat housing) is the correct one. uhh btw once u unscrew the std probe. . .ur gonna get coolant coming out so dont forget to at least partially empty the cooling system b4 u give it a shot
sounds dirty.
