the master fuel is main mixture and will change the main map as well as the starting.
You need to tune the master when the engine is at temp to get the fuel table numbers in an acceptable range,
then play with the temp settings when cold to get it right.
Changing the master fuel by 1 or 2 will have a big change.
What engine and what injectors are you using?
