Results 1 to 3 of 3
Thread: What is the difference in ke72 subframe and ae86
    May 2017
    sc
    Default What is the difference in ke72 subframe and ae86
    Doing a 1uz swap in a ra28. I need a subframe to make it rack and pinion.
    oregon
    Default Re: What is the difference in ke72 subframe and ae86
    Quote Originally Posted by gearbound View Post
    If both are rack based cross members, they are nearly identical. I remember checking AE71 FSM front end specs with AE86 FSM front end specs, and one spec was 1mm different, but all the others were the same
    FSM scans here - http://www.toymods.org.au/forums/thr...l=1#post897348
    Edit - the front subframe mounting hole is 1mm wider/different: The AE71 = 780mm, the AE86 781mm
    May 2017
    sc
    so itll work. then all i need is a aw11 manual rack or ae86 rack. id like to keep power steering but im not sure if it will fit.
  1. TA22 vs TA23 Subframe
    By khearento in forum Tech and Conversions
    Last Post: 08-04-2015, 07:37 PM
  2. 1990MA70 subframe vs 1988 mz20 subframe
    By Spindevil in forum Tech and Conversions
    Last Post: 01-05-2010, 10:07 AM
  3. subframe bushes on rt142
    By darryl in forum Tech and Conversions
    Last Post: 18-02-2008, 07:45 PM
  4. A70 rear subframe bushes
    By HKS_TRD in forum Tech and Conversions
    Last Post: 13-11-2007, 06:16 PM
