Results 16 to 24 of 24
Thread: T series Trannys?
    Default Re: T series Trannys?
    Good luck welding flat steel to a cast alloy bellhousing.
    Heh, norbie has a very correct observation....
    yeah, sorry wasnt thinking, welding alloy to cast alloy can be tigged but will leave easy tear line
    Hoppers Crossing
    merc-blue : yes it can be welded. alloy to alloy only though.
    as long as the penetration is good and the welder doing the work has a MIG or better still TIG to do this, the tear line won't be an issue due to the bellhousing being supported by the 6 or so other bolts around it.
    i bought a A series to W box bellhousing some time back and this is exactly what had been done (looked like MIG from what I could see) but had been surfaced and cleaned up very nicely.
    so yes very doable, but, not really worth it (at all)
    I also need a suitable bellhousing for a 3tgte/w58 but if the g series bellhousing puts the starter on the passenger side then thats possibly unusable depending how much room i would end up with for an exhaust.
    I have a 3T-GTE in the car atm but i don't know what box it is, but simply what i'll need is either a w55 box on there so i can use the bellhousing, or try my best with the 1g one.
    Are there any other options available (btw dellow is not an option) and can a standard 3T clutch be used with the 3T flywheel and W58 box?
    - LeeRoy
    New Zealand
    I don't think starter on passenger side is a major, thats where the factory 3T-GTE one sits anyway.
    Callum
    Actually i think your right plus i just had a look and there some steering component that looks like it will give me more grief anyhow.
    Hoppers Crossing
    leeroy, i have a 3" dump pipe which i made cruising past my starter motor - and i have a 2T - so its really not an issue.
    I've also got a 3" dump pipe atm but i havent gotten the rest of the exhaust done yet as i didnt have enough money at the time and i also dont have the w58 under the car. This will all be getting done in a few weeks.
    I'm pretty sure that the box on the 3t looks different to the box on the 2t in my garage plus the shifter is in a different position. Whats the chance that its got a w55 on it already in which case i can use the bellhousing on it cant i?
    [Edit] i was just thinking does the g series bellhousing place the box back furthur or its pretty much identical to that of the T-W series housings?
    - LeeRoy
  1. Guide: How to build a K series motor
    Last Post: 19-10-2007, 08:43 PM
  2. Imports101 MaxAction Second Series 2006
    By GeneSPIDA in forum Western Australian Events
    Last Post: 10-12-2006, 07:17 PM
  3. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 05:14 PM
  4. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 07:51 PM
