Results 1 to 3 of 3
Thread: need help !!! only one barrel works on 18R carby
    Nov 2016
    haikal
    Unhappy need help !!! only one barrel works on 18R carby
    hi guys ,
    when I bosh the gas and see inside the carby I found only one barrel work
    I wanna help as the image shown
    thanks a LOT
    Default Re: need help !!! only one barrel works on 18R carby
    I will hazard a guess that that barrel is a vacuum secondary which will not open until the engine is under some kind of load and there is little to no vacuum in the manifold. To see that barrel open you will most likely have to have the throttle wide open not just some higher rpm in neutral.
    Of course you may already be on top of all that and it may have a buggered diaphram in the vacuum thingy which should control that barrel.
    Jason
    Nov 2016
    haikal
    thanx for replaying mr Jason
  1. Advantages of barrel i/c
    By Dimmy in forum Tech and Conversions
    Last Post: 30-09-2008, 10:19 PM
  2. Turbocharged carby motors, which carby?
    By Pimpin_1JZ in forum Tech and Conversions
    Last Post: 09-07-2008, 10:15 AM
  3. Which Wire goes Where: Ign Barrel AExx
    By The Last Streetfighter in forum Tech and Conversions
    Last Post: 21-11-2006, 02:11 PM
