Results 1 to 15 of 16
Thread: Turbocharged carby motors, which carby?
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Default Turbocharged carby motors, which carby?
    Hi, basically as title states I'm looking at turbocharging a carby car. Is there a specific type of carby of which I should be looking for? Fabricating is easy for me so the rest of it is no drama's. I'm loking to do a suck through style, just concerned as to which carby or is it a case of whatever you like?
    Thanks Adam
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    no backyard Domestic Engineer japlish's Avatar
    Default Re: Turbocharged carby motors, which carby?
    su type carby for suck-through and weber for blow through, webers can hold about 12psi before stuffing up (use a rising rate fuel regulator with it)
    Destroyer of 'Drop Forged' spanners
    Bunbury W.A.
    Okay cool, thanks for your help, I will start looking into some SU's
    how many cc is the engine? there might be a similar sized engine you can grab a carb and other gear from ie nissan exa or daihatsu charade turbo or sigma turbo
    Forum Sponsor Conversion King
    Quote Originally Posted by Pimpin_1JZ
    Microtech? they're very similar to a carburetor, just an electronic version the carby would probly start easier with the choke on.
    I can't think of any reason in this day and age to want to go carby & turbo!
    Ok I lie, I guess you could want to do it as a learning experiment / something to do
    But megasquirt / EFI is cheap these days, and will have much better results! Might be worth thinking about?
    weber DMTT?? if you can find one.. or get one prepped fro pressure.. but then once tuned etc, is probabyl more expensive that a microleb or megasquirt, for half the result.
    edit, here is a nice essay from Jmac
    http://www.performanceforums.com/for...-67183760.html
    fwiw: a re-jetted Zenith Stromberg carbi (e.g. model CD175) worked on my old setup (draw-thru) which was an 18R with low compression and cam to suit turbo. Required custom manifolds and re-graphed dizzi and colling system improvements ... and was still a PITA.
    ... i've since vowed to never own or drive a carbi-fed car.
    Bunbury W.A.
    Well basically I race autocross (low end rally), for the new season I'm looking for a KE2/3/5/7 as a new base car. We have built a new track and the RT142 corona isn't going to be up to this track so I am after something smaller. So I was thinking a corolla with a 2t/3t and turbocharge that. So pretty much it is a learning excersise, if I kill it it won't matter as it is really only a fun car for me. There are 4 runs per round at about 1:35 seconds so it doesn't have to last all that long anyway...
    Moderator Grease Monkey Pumpkin's Avatar
    Pimpin 1JZ... I have a SU carby used for a suck - through setup on a 2T. I had a few bits come to think of it including a decent head.. I will have a look..
    Yours if you want it.
    Pumpkin
    2TGEU Mustard TA23 -- It's back... Just not in one piece .
    M-EU White MA45 .. -- SOLD...
    Audi A4 1.8T .. SOLD
    For draw through I have used SD webbers with good results. They get a little fiddley to set up/tune but once they are I think its a great set up.
    Are you going to use an intercooler?
    Just had another look. Sorry Pimpin_1JZ, mines actually a Stromberg.
    Still, yours if you want it ...
    Pumpkin
    Bunbury W.A.
    Hmm, what sort of stromberg is that pumkin?
    Bunbury W.A.
    Quote Originally Posted by IS1000
    Well it isn't going to be running for all that long at a time. So really there is no need for it. Plus it is a suck/draw through style I'm doing so the intercooler idea won't really work.
    Plus it is a suck/draw through style I'm doing so the intercooler idea is really dangerous and shoudl never be done in this configuration.
    fixed... 123
  1. Are 3sge beams motors interference motors?
    Last Post: 21-04-2007, 04:31 PM
  2. 4K-C carby query
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 26-03-2007, 01:01 AM
  3. 18RGU Carby and Cam Questions (long winded and a few pics)
    By floppy in forum Tech and Conversions
    Last Post: 06-01-2007, 11:25 PM
