I think that's the first UZ to Hiace conversion iv'e heard of-noice!
Regarding you question could you clarify the noise that your hearing?
Also, could you clarify what kind of fuel system plumbing you have.
I don't have enough information to guess what the problem is, but I can think of a few tests that may narrow it down.
1- Test start from cold early. Do several quickly while the engine and fuel system are cold.
2- Get car up to temperature and stop the engine. restart it quickly and note how the fuel system sounds. Then turn it off, leave it for 15 minutes to allow heat soak then restart.
Its unlikely that you have enough heat going into the fuel system to boil the fuel while it is circulating. It takes a lot of heat to vaporize fuel under pressures as found in the feed side of a EFI system.
If fuel IS being vaporized in the return line then it shouldn't matter as it can vent back into the tank. I would guess its most likely your fuel pump, as that's the only moving element in your fuel system(with the engine off) and thus the most likely cause of any noises that your hearing.
The other possibilities I can think of would be hydraulic hammer if you had a restriction in your return line, but that would be pretty unlikely IMHO
) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
