Results 1 to 2 of 2
Thread: ae101 gt-z crank angle sensor on 20 valve silver
    AB
    Default ae101 gt-z crank angle sensor on 20 valve silver
    does anyone know if i can use the crank angle sensor from an ae101 gze engine on the silvertop and still use the s/t ecu? trying to avoid cutting out the firewall as the engine is going into a rwd configuration. if anyone has any ideas on how to make this work please let me know. thanks in advance
    Default Re: ae101 gt-z crank angle sensor on 20 valve silver
    20v has a keyway on the dizzy and will only fit one way
    gze has a gear and is much longer and can fit many diff ways
    yr better off removing the dizzy cap and rotor
    and gettin a twin coil setup
    but if u wan tto use the silvertop ecu u need a signal splitter and 2 ignitors
    this gets very expensive and at the end of the day i think its better to pay alittle bit more and get a microtech ecu
    dont fuk round tryin to run std silvetop ecu without the s/t dizzy and single coil
    thats my opinion
    By The Witzl in forum FAQ
  2. T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
