Results 1 to 3 of 3
Thread: 7AGE dies when hot
    Default 7AGE dies when hot
    Hi All,
    I haven't been on these forums for an eternity but I'm hoping somebody can help me.
    I've got a 7AGE with a bigport head, silvertop throttle bodies and mild cams in an AE86.
    It is running an Adaptronic e420c with a Coil on Plug setup from what I recall as being from a Toyota Echo.
    The cam angle sensor is a modified 4AGE distributor in a 24 + 1 setup (the other three teeth were ground off).
    Other than occasionally being reluctant to start the engine has been running quite well. There is no idle control so it struggles a bit with multiple electrical loads but is usually okay.
    The other day I got caught in traffic and it became quite hot but the thermofans managed the engine temperature. After quite a while of being in the traffic it started to struggle to idle (spluttering) and eventually died. I could start it again but couldn't get it to idle. Once it had cooled down it started and ran fine for a short period of time.
    The next day I started it and it ran fine until it got up to temperature and started spluttering before it died again.
    I've plugged a PC into the Adaptronic and logged the moment where it dies but everything appears to be okay as far as I can tell.
    Before I start trying to hunt for another distributor and/or coils does anybody have any thoughts on what else could be causing this?
    Any suggestions would be greatly appreciated.
    Thanks,
    Blake
    Jul 2007
    Default Re: 7AGE dies when hot
    do you run a walbro 255 fuel pump by any chance?
    Thanks for your reply.
    It has a cube style lift pump filling a small surge tank and an old VL Commodore spec high pressure pump.
  1. 7age: how to?
    By iflylo in forum Tech and Conversions
    Last Post: 03-12-2015, 08:02 AM
  2. 7age 20v Build
    By Levin AE92 in forum Tech and Conversions
    Last Post: 30-07-2013, 09:38 AM
  3. 7age 20v stroker?
    By 13anshee in forum Tech and Conversions
    Last Post: 29-08-2011, 10:03 AM
  4. 7AGE 20V 6 speed
    By Bazooka in forum Tech and Conversions
    Last Post: 16-03-2007, 09:47 PM
  5. 20v BT head on a 7AGE
    By chadix24_7 in forum Tech and Conversions
    Last Post: 09-03-2006, 10:00 AM
