Results 1 to 8 of 8
Thread: what rear diffs with disk brakes bolt straight into a ke70?
    Aug 2016
    victoria
    Question what rear diffs with disk brakes bolt straight into a ke70?
    hey guys im new to this forums stuff so sorry if im a bit nooby
    i was just wondering what rear diff disk brakes would bolt straight into my ke70? as i wanna remove the drum setup
    Victoria, Mt Macedon
    Default Re: what rear diffs with disk brakes bolt straight into a ke70?
    Bolt straight in? Only a JDM AE86 diff will do that. And you'll need a tailshaft to suit. But they are usually overpriced and have OK rear discs and crummy handbrake from what I hear.
    Depending on what you use the car for and what power you are pushing you could look into:
    T18 (TE72) diff with ST141 Corona discs. Alternatively RA40 and possibly RA60 diff housings fit with minor mods and take the Corona discs too.
    For something larger I like the MS112 Crown F series diff. 50mm wider and needs housing modified to fit, but otherwise has good brakes and great handbrake.
    G-series Hilux diffs are strong, have various widths and there are options available to put discs on them fairly easily too.
    That's the tip of the iceberg of possibilities you have for non-bolt-in.
    Aug 2016
    victoria
    is there much modification needed to fit a t18 with corona discs?
    T18 diff bolts straight in. Needs tailshaft to suit, exact one depends on your motor/gearbox.
    Corona discs - https://www.google.com.au/search?q=c...ur+stud+toyota
    A little more info about your car, what you use, or plan to use, it for, reasons for wanting discs, budget, etc, will make life much easier for people trying to answer your questions and offer relevant advice.
    Aug 2016
    victoria
    does the t18 come with disc brakes?
    im planning on putting an sr20det in my ke70 for street use.
    May 2006
    tas
    T18 uses drum. But they are larger drums then stock ke70.
    Aug 2016
    victoria
    Would a t18 fit in a ae71?
    Yes, KE70, AE71, TE72 and AE86 all have the same mounting points on the diff. Some TE72 diffs don't have swaybar mounts, but you can buy weld-on ones.
  1. hilux disk brakes on R31 diff? Do they fit?
    By Ashh in forum Tech and Conversions
    Last Post: 05-03-2015, 10:05 PM
  2. R31 disk brakes rear end of ta22
    By Digiorgio1 in forum Tech and Conversions
    Last Post: 05-05-2011, 12:29 PM
  3. 7MGTE into mx10 straight bolt on?
    By da12nv in forum Tech and Conversions
    Last Post: 17-07-2008, 12:04 PM
  4. 7MGTE into mx10 straight bolt on?
    Last Post: 24-06-2008, 09:07 AM
  5. G-series Disk brakes (searched)
    Last Post: 08-02-2007, 10:57 PM
