Results 16 to 22 of 22
Thread: Aircon issues after 1jzgte conversion is200
    Jan 2016
    buraim
    Default Re: Aircon issues after 1jzgte conversion is200
    yes This ecu have immobilizer on it I. took the ecu to a repair shop keys They reset the Immobilizer chip and They program the is200 key .
    Is your A/C pressure switch hooked in to the ecu / yes
    gas in system / yes
    engine temperature reading / yes
    All gauge in cluster working properly
    climate control system working properly Except the A/C not work
    POWER/SNOW modes of auto trans working but not properly
    cruise control / Not checked
    Traction Control / Not checked
    fuel Gauge working properly
    MPG Gauge working properly
    speed Gauge working properly
    rpm gauge working properly
    Aug 2015
    berbice
    Nice.. so you just unplugs the jzs171 ecu and plug the jzx110 ecu? You did change and sensor? What about the what about the performance? And what about the e-shift do the jzx110 have it like the jzs171?
    Aug 2015
    berbice
    Quote Originally Posted by al waleed View Post
    gas in system / yes
    al waleed... up date us on your aircon issues .. have you get it running like stock with the fix from George?
    Jan 2016
    buraim
    Quote Originally Posted by hititup View Post
    So far, no \
    I received this message from George (Hi
    I can make device to control 4 features of JZX110 ECU: idle up for elec. load, a/c , power/snow mode
    It will not do anything to GXE10 dash or climate control unit
    However I plan to begin working with Altezza things later)
    Aug 2015
    berbice
    gas in system / yes
    I am thinking of getting a jzx110 ecu too from ebay I see 1 for $150us.
    2 things will determining if i'll get the jzx110 ecu. I want to know if my old is200 eeprom immobilizer chip can be flash to the jzx110 ecu. And if the jzx110 ecu support e-shift (Paddle Shifter ) like the JZS171 ecu?
    We dont have any place here dose this kind of thing so i will be doing it myself.
    Jan 2016
    buraim
    jzx110 ecu not support e-shift and i Notice if i drive slowly Transmission shifting Will be fast .
    I think needs to change the JZS171 Transmission to jzx110. and Regarding the old is200 eeprom immobilizer chip I do not know I do not know if this method will succeed.
    cruise control / working properly
    Traction Control / Not function
    Aug 2015
    berbice
    any more update.. Are you sitll running the JZS110 ECU or you went back to the JZS171 ecu?? can i see the inside of your JZS110 ECU? (pic) i want to know how to do the eeprom things. i flash the eeproms on TVs ..
    i find my tranny not shifting to 4th.. say if i am 3rd or 4th the RPM the same.
  1. Is200 Manual Shifting Issues
    By finch in forum Tech and Conversions
    Last Post: 29-01-2014, 04:25 PM
  2. Aircon Issue 1JZGTE
    By JZA70R_92 in forum Tech and Conversions
    Last Post: 08-01-2011, 04:23 PM
  3. Aircon in an ra28 + 1jzgte + no room in front for condensor
    By 77GZE in forum Tech and Conversions
    Last Post: 22-10-2008, 09:19 PM
  4. 1JZGTE VVTi/IS200 cutting out on load?
    By nite b in forum Tech and Conversions
    Last Post: 26-08-2008, 02:18 PM
