Results 16 to 30 of 32
Thread: Jzx100 VVTI 1JZ starting/Idle issues
    Aug 2006
    Default Re: Jzx100 VVTI 1JZ starting/Idle issues
    It flashed constantly at a high rate with the terminals bridge so it appears that there are no codes.
    Thanks for the info.
    Will give the AFM thing a go.
    Could a faulty ISCV cause these symptoms?
    Quote Originally Posted by George View Post
    what exactly happened when you bridged the terminals? No error codes would make the warning light constantly flash at high rate.
    Coil bottom rubber seals can fade over time, also coil's case may contain small cracks, sometimes barely visible but enough to lose voltage before it gets to the plug
    vvti cam gear is big stuff driven by timing belt. It has two rubber seals which can develop leaks, and it can also seize
    AFM: disconnect battery, disconnect AFM, try to start. Should run ok at low rpm without AFM
    May 2010
    Moscow
    Can be potentially, but last time I personally seen toyota engine with iscv was about 3-4 years ago. Those with etcs-i have no such problem, it either works or not
    Aug 2006
    I just tested the ISCV as per these instructions- http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=107
    It is showing the resistance at around 45. It says that it should be between 10-30ohms in that manual... Is this going to be an issue, as in the manual it says that if it isn't between those values then replace the valve. I then did the second test and it opens and closes the valve as it should, does this mean it's ok?
    May 2010
    Moscow
    should not be an issue as long as both the valve itself and what's behind it are clean
    Back in the days I was working with these older engines the two main issues were carbon buildup and improper wiring of master efi relay
    Aug 2006
    Hmm any other ideas? Not worth just trying another iscv just in case?
    May 2010
    Moscow
    that's always a good option if you have access to another iscv
    Aug 2006
    Fully closed the iscv manually using the testing method and then connected it up to the plug. When I turn the ignition on/off I hear some clicking at the iscv, but upon inspection it has not moved to the open position.
    It looks like the iscv is either stuffed or it isn't getting the correct signal.
    May 2010
    Moscow
    more likely to be stuck than something else, but it's worth checking ECU earths (ignition on, ECU connected , measure voltage between battery negative and each earth of ecu, anything above 0.5v is bad)
    Aug 2006
    Thanks for your help mate will check it out
    Aug 2006
    Swapped out the iscv and it seemed to be ok for a short while....drove to shops and when I went to start it it revved to around 2k! Drove it home and it was idling around 800rpm. Started it up before and it just wants to stall. Seems like it has just shut off the iscv valve.
    I tested the ecu grounds and they all tested ok. Also tested continuity to the iscv pins from the ecu to the plug and they seemed ok too.
    Any other ideas? What other sensors does the ecu use to tell the iscv to open? Tps?
    Aug 2006
    I used the 2j spec sheet to test the TPS. E2 to VTA1 was within spec but the IDL to E2 was showing 3k ohm closed throttle.
    Does this indicate a faulty TPS as it says it should be .5k ohm when closed? Don't want to buy something else that it isn't!
    May 2010
    Moscow
    You should test the IDL/E2 resistance with battery disconnected and ECU disconnected
    Aug 2006
    That is testing with the throttle body off the car nothing connected
    Aug 2006
    TPS definitely looks to be stuffed. It's resistance is going down when it is opened.
    Back probed the TPS with it connected and ignition on. E2 to IDL is showing 5v on closed then decreases from there when opened.
    May 2010
    Moscow
    Check that there's always zero volts at TPS's earth terminal (with TPS connected)
    If so and the above is still observed then it's surely stuffed
  1. jzx100 chaser bad idle
    By blktoy in forum Tech and Conversions
    Last Post: 24-09-2010, 10:28 PM
  2. 1JZ-GTE VVTi JZX100 Chaser - Wiring, Please Help!
    By walky_talky20 in forum Tech and Conversions
    Last Post: 09-01-2010, 02:51 AM
  3. 1uz's which version to get...is vvti the better starting point
    Last Post: 05-11-2009, 08:36 PM
  4. 7m starting issues
    By Disturbed1 in forum Tech and Conversions
    Last Post: 04-08-2007, 02:00 PM
  5. 4AGE Starting / Holding Idle problem
    By thanhngo in forum Tech and Conversions
    Last Post: 05-01-2007, 12:13 AM
