Results 1 to 3 of 3
Thread: Transplant - Lexus IUZ-FE vvti into Land Rover Freelander
    Jul 2016
    KwaZulu Natal
    Default Transplant - Lexus IUZ-FE vvti into Land Rover Freelander
    I am putting a Lexus V8 motor, automatic gearbox, into a Freelander. Can someone please supply me with a wiring diagram for the ECU and gearbox to connect the conversion. The original diagram does not help as I need to know which wires go where so that I can mach up to the Land Rover wiring
    May 2006
    tas
    Default Re: Transplant - Lexus IUZ-FE vvti into Land Rover Freelander
    There should be notes on wiring diagrams for connectors like 'e15' which you can cross reference to a connector diagram often at the start or end of the diagram.
    I cant say if the 1uz pinnouts change from model to model, but always double check that it looks right.
    Checkout wilbos website, lot of good stuff on there. He is a member on here to.
    http://wilbo666.pbworks.com/w/page/37092272/Wiki%20-%20wilbo666
    I don't have any 1UZ-FE VVTi information personally sorry.
    If someone has the proper Toyota wiring diagrams they want to supply me then I'm happy to look at adding the info to my site tho...I'm a bit picky on quality however just to let you know!
    Also you haven't said what your donor engine is from!
    People need specific information to be able to help you! Things like the engine ECU part number, car model code, etc are very helpful! We can't read minds!
    Finally, if you have the engine ECU pinout, then you should be able to "trace" the pinouts of the engine loom to body loom plugs (and any other plugs on the loom) using a multimeter!
    It's a bit more work to trace back from the engine ECU plugs, but sometimes it's the only way
    Wilbo's JZA80
    Wilbo's JZZ12
  1. motor transplant
    By aliens55 in forum Tech and Conversions
    Last Post: 27-11-2013, 09:59 PM
  2. Rover 3500 V8 - Information for conversion
    By Radar in forum Tech and Conversions
    Last Post: 19-07-2008, 12:48 PM
