Results 1 to 2 of 2
Thread: wiring instructions for Jzz30 1jz into mx83
    May 2012
    Default wiring instructions for Jzz30 1jz into mx83
    Hi guys after a wiring diagram or instructions for a jzz30 1jz engine loom into mx83( S2 Grande).
    Any links/videos, ect would be appreciated.
    Feb 2016
    Default Re: wiring instructions for Jzz30 1jz into mx83
    Come on man.
    Search.
    ECU Pinout and Body Pinout from JZZ30 - http://wilbo666.pbworks.com/w/page/4...ngine%20Wiring
    MX83 S2 Plugs behind Glove Box
    White plug
    yellow with brown spots___________ speedo speed sensor
    brown _________________________ speedo speed sensor [make sure you earth this one]
    yellow_________________________ temp sensor
    black__________________________ tacho
    yellow/blue _____________________ oil pressure switch
    red/green [2] __________________ reverse
    green__________________________ park
    red ___________________________ neutral
    blue___________________________ drive
    light green______________________ 2
    pink __________________________ L
    Square grey plug
    small black/white _______________ AC clutch
    blue/red_______________________ FP diags
    black/red _____________________ +B diags
    red/black _____________________ 12v supply for speed sensor etc
    big black______________________ nsw
    big black/white _______________ nsw from start relay
    light green ____________________ goes to purple/white in other grey plug
    green with spots _______________ tccs diode
    green/white ___________________ stop light switch
    big black/yellow________________ power from ignition
    small black/yellow _____________ solenoid 2 in transmission to cruise control ecu
    green________________________ from airflow for circuit opening relay
    black _______________________ from temp sensor on water inlet to start injector
    Rectangular grey plug
    pink__________ _______________ TE1 diags
    brown/black __________________ earth
    pink/green__________ _________ TE2 diags
    grey________________________ VF1 diags
    purple/white__________________ goes to pink. and light green in other grey plug
    grey/green___________________ brown wire on abs sensor
    pink/blue ____________________ grey wire on abs sensor
    purple ______________________ blue wire on abs sensor
  1. 1jz-Gte JZZ30 Wiring?
    By gmonkey in forum Engine & Driveline Conversions
    Last Post: 26-04-2012, 08:19 PM
  2. JZZ30 a340e speed sensor wiring into MX83
    By Cressii in forum Tech and Conversions
    Last Post: 17-03-2012, 01:38 AM
  3. jzz30/jzx90 wiring info.
    By celupra in forum Tech and Conversions
    Last Post: 09-12-2011, 02:44 AM
  4. Replies: 6
    Last Post: 08-01-2009, 12:57 PM
