Results 1 to 14 of 14
Thread: 2JZ//MX83 overheating
    Oct 2009
    Default 2JZ//MX83 overheating
    Looking for some ideas;
    I have a 2JZGTE in a MX83 -
    50mm full alloy rad
    600x300 IC
    AC condenser
    Oil cooler
    Twin 10" spal fans in a shroud
    Situation is that when cruising around its alright, will sit on mid to low 90's but if I jump on the freeway and do 110 with the AC on it will overheat if I let it, same deal if I have to drive up a large hill doing the speed limit. Its always run with the fan essentially running, it had a controller that cut them in at 100c but they will always cycle on and off regardless. I've removed that but if I drive around with them off it will run hotter than with them on....
    Of late I think its been getting worse....
    Radiator checks out fine but I'll replace it anyway
    Thermostat is mint, was replaced 12 months ago and it tested fine today
    Coolant is mint, genuine toyota.
    Nothing has really been fucked with in the front end, though the front bar is a shitty design that doesnt help.
    It is missing the plastic undertray and there is a gap (50mm) between the IC and the condenser.
    My current state of thought is to fuck off the thermo's, fit a 2JZGTE viscous fan with the standard MX83 shroud, put an undertray in and plug all the gaps I can see.
    Anyone here have suggestions?
    Default Re: 2JZ//MX83 overheating
    Put the under tray back on. South had overheating issues on the freeway til he reinstalled it, then all sorted (from memory)
    Never late in an x8
    Oct 2009
    Thoughts on getting the viscous fan working?
    Jul 2007
    i would start with the undertray/proper shrouding all around the radiator as well. LS1 e36 we built literally would refuse to keep temp until we installed every single tray/shroud back on. then it was apples
    Air blocked somewhere is the next thought. Heater core ?
    Auto trans got its own cooler?
    Oct 2009
    Bled it good and proper, not running an auto.
    Oct 2009
    Trying to work out what fucking combination works.....
    Advise is all over the shop
    2JZGE fan & clutch with the fan trimmed is the go?
    heap of shit out there on using a LS400 clutch but idk
    Stupid lebo **** wreckers sold me the wrong fan/hub a week or two ago, will try swapping it tomorrow for a NA supra one.
    Found a shroud down the gong along with an undertray.
    Oct 2009
    Have obtained a fan shroud, undertray, 2JZGE fan and clutch~
    Did a trail fit today, fan will clear the radiator and shroud no worries however it will hit on the top radiator hose and water neck (expected).
    Most people trim the fan half an inch to clear the hose but fuck that, that's precious CFM going to waste. I dont run the mid timing cover so I'll chop 15mm out of the water neck and not touch the fan.
    Should be able to tig it up tomorrow, will see if I can get a new radiator at the same time.
    Oct 2009
    Fuck the CFM, just cut it. You don't need 3500CFM to keep the motor cool at idle / low speed. Technically your fans shouldn't even be running while on the freeway, it's only because the issue is elsewhere that they are running to try and reduce temps.
    We have customers with big block V8's using a 200CFM Spal fan and have no problems, the clutch fan is overkill (aka Toyota), but I wouldn't worry about giving it a trim up.
    Oct 2009
    Water neck has been cut, I'm dropping by your work to weld it tomorrow.
    May 2006
    tas
    I had issues until I removed a/c condensor.
    Still runs hotter then id like 88-90 crusing at 110 on the flat, 92 on a steady hill.
    Having the under stray on makes no difference to temps on the highway, have defi water and oil temp gauges.
    Oct 2009
    Those temps are fine, like, that's what a brand new JZA80 would run at.
    Anything sustained under 100c is fine, anything from 100-110c is fine if its every now and then and anything beyond that is problematic.
    Yet to put it all back together, maybe might get it done tomorrow but probably not.
    There is still a feeling in the back of my head that I've done something more sinister but eh, we shall see. The setup hasnt changed, undertray has been off for a while but admittedly I think it was removed in autumn last year. Marginal cooling system's generally dont have issues during winter
    If its done a headgasket then its not such a bad thing, I have cams to swap in, stem seals to change and a turbo/manifold to ceramic coat so its not much more work to r&r the head.
    Oct 2009
    Got it together, took it for a drive, seems better.
    Nearly wiped off the front cutting hoops so I'll have to wait till I'm either not such a shit**** or wait for a hot day and go on the freeway.
    On the lookout for a better undertray, mine aint terrible but its wonky and fucked.
    May 2006
    tas
    I think they must all go like that. Mine always looked wonky, streched and slopped out like a old vag.
    Also re:temps I don't like my oil temps higher then 110, otherwise oil starts breaking down pretty quickly after that afaik. High water temps don't help oil temps. Not trying to redesign te engine just I don't like water temps over mid 90's when driving hard.
  1. 7m overheating
    By Huz in forum Tech and Conversions
    Last Post: 17-03-2010, 06:51 PM
  2. 1uz overheating
    By mr plow in forum Tech and Conversions
    Last Post: 25-05-2009, 07:48 AM
  3. how can a BHG cause overheating?
    By SL666 in forum Tech and Conversions
    Last Post: 12-01-2009, 04:41 PM
  4. overheating 3s-Ge
    By RohaN in forum Tech and Conversions
    Last Post: 21-11-2006, 10:39 AM
