Results 16 to 24 of 24
Thread: timing vs boost vs comp vs ron??
    Default Re: timing vs boost vs comp vs ron??
    Which bit did you want explaining? Basically, a richer mixture generally is cooler than a leaner one. If you're running lots of boost, it's nice to have a safety margin because temps will already be hotter due to the bulk charged air being pumped in.
    Junior Member Domestic Engineer mic*'s Avatar
    Yeah, that makes sense to me.
    I was just reading something backwards i think...
    more boost = hotter -therefore need- lower AFR = richer
    (very generally)
    meh...
    Quote Originally Posted by 1jzracing
    AFR? ... just keep it FAT up top or it'l overheat the piston and damage it ideally 11.5:1 or lower on anything over 20psi
    12.5 sooty is what i use
    Junior Member Backyard Mechanic 1jzracing's Avatar
    sorry buddy was going to send a reply im just a slack-ass!
    cant say i recognise the car in the pic looks a bit like the ones who run with us they all pretty much follow a similar theme ... steve vigors has claimed to have built quite a few chassis including jackos calebra how do you know that car so well? ... its fast but so nervious and twitchy!
    i definatly hear what your saying about intercooling, ive had quite a few goes at getting it right from medium FMic ... was ok bit of pressure loss....to a big water air... totally sucked!! ... just heat soaked and temps hit 65+ degrees..... buy buy to no6 piston.. now using a biger FMic seems to be ok with intakes down around 45degrees at 23psi
    i seem to be on the right track picked up a forth a third and second in the feature last weekend and we punched out 354rwkw not bad for a dead stock $900 short block in a full floorpan car, std firewall! ..... but still theres always room for more!! ....
    hehe think that puts me ahead of jackson in the points now
    pm you some tech stuff
    that chassis is totally difffrent from the steve vigors one. it had the whole front cut off and redone properly and i add 10 or so piece of cage to try and fix it! all the alloy inside is new!
    the rear set is redone! had to spen $75k to make it a half decent car. even wiht all that the chassis was that bad it still bends! have a look and the height of the bottom of the drivers side firewall and then the other side! the drivers side is slowly bending up!
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    With my setup I am running 16 degrees with ~19psi of boost and BP 98 ron. (Can't get shell where I live). This was the old tune but am to go back for another tune with some more fuel and boost very shortly, will post up the results aswell. Timing looked about perfect for the setup according to the line on the plugs. So we didn't push it any further. We left timing until the end and managed to pick up 40rwhp from it.
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Buenos Aires
    Quote Originally Posted by JustCallMeFrank
    I´m sorry but this is wrong. Leaner mixtures burn slower, that´s why they seem hotter. The opposite is true too: rich mixtures burn faster and that´s why they seem cooler.
    When a mixture burns slower, there is "fire" for more time when the piston moves downwards and thus there is fire in contact with cylinders for more time. That rises engine temperature. Similar thing happens when you retard your timing.
    now 18rg powered... Grease Monkey 18rc turbo's Avatar
    Jun 2006
    as my signature suggests i'm running an 18r-c turbo, 14 psi (has been as high as 20 psi), with 24 degrees ignition timing. And as far as i could work out when i had the head off, i'm running 12.4:1 comp ratio. And i'm running straight LPG (which i have been told vary's in between 100 and 110 RON. don't know if this is true or not though...?)
    3 x RA23's + 2 x RA28's = No Backyard!!
    18r-g + straight lpg + t25 turbo + 14 psi = FUN!
    The latest Toy : http://www.toymods.net/forums/showthread.php?p=807137
    Nath #347 Backyard Mechanic PHOBIA's Avatar
    A totally different engine than the ones referenced here, but for the point of this thread my 22R-E is tuned with the following.............
    12 degrees of timing advance with 25psi of boost on 100LL Avgas. Air/fuel ratios of about 11.5:1 with a compression ratio of 8.5:1.
    1986 RT-142 Corona. Taking the phrase “WTF”, to a whole new level......
    PHOBIA. Fear of.........investing your soul into customizing a "f@#kin what" a Corona???
    Click to see PHOBIA
  1. question: Low CR vs. High CR for forced induction?
    By AndyTTR in forum Tech and Conversions
    Last Post: 24-11-2009, 05:11 PM
  2. Boost Leak Tester
  3. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  4. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
  5. 2tgte comp Qs + backyard anti lag Q
    By cooter in forum Tech and Conversions
    Last Post: 09-03-2006, 07:46 PM
